Old Mar 23, 2018 | 10:17 AM
  #5031
Sixpack577's Avatar
I've used oil on faded exterior black plastic for years.
Unless you drive on dirt roads, I've never had a problem with dust or dirt sticking, but even dirt road dust just wipes off, and the black still looks good.
As said, it takes a few rains to wash it out, then just reapply.
I'll try the scrubbing bubbles too.
As for the Pledge(I've been riding sportbikes 23+years), there is nothing better for cleaning bug guts off of plastic, metal, and headlights.
Spray on heavy, let soak for minute, wipe off 90% of the crud, spray and wipe again with little effort, polish to a shine and done.
Better than any bug and tar remover and even HondaPolish...and smells like lemons too, lol!
Old Mar 23, 2018 | 10:18 AM
  #5032
Alex_M's Avatar
Originally Posted by mollusc
DOT 5 brake fluid works well too, and doesn't get sticky or hold dirt.
Not any other DOT. Not 3, not 4, not 3/4, not 5.1. Only DOT 5. It's the silicone based one.
Correct me if I'm wrong, but I thought that you were NOT to mix the silicon based stuff with the traditional stuff. Right?
Old Mar 23, 2018 | 10:19 AM
  #5033
Sixpack577's Avatar
I'll try that too, thanks
Old Mar 23, 2018 | 10:21 AM
  #5034
Friday Night Disco's Avatar
To be clear, I have only used the scrubbing bubbles on the engine bay.
For outside trim I stick to the typical plastic/ rubber cleaners.
For bug, I use claybar
Old Mar 23, 2018 | 11:42 AM
  #5035
mollusc's Avatar
I'm not talking about using it as brake fluid. Use it to clean plastic and metal parts and have a nice finish afterwards.
Old Mar 23, 2018 | 12:02 PM
  #5036
Alex_M's Avatar
My mistake, I missed that.
Old Mar 23, 2018 | 05:14 PM
  #5037
Jeff Blake's Avatar
Feels good to take weight off for a change.. from the wrong end however
A good 40 pounds lighter!
If anyone wants to buy SlickRockFab quick disconnects or cross member spacers, pm me.
Old Mar 23, 2018 | 06:26 PM
  #5038
JUKE179r's Avatar
How does it ride on the street with the front sway bar off?
I'm thinking of removing my sway bar but still reading up on the pros and cons of removing front vs. rear for street driving.
Old Mar 23, 2018 | 06:32 PM
  #5039
Jeff Blake's Avatar
I'm thinking of doing mine but still reading up on the pros and cons of removing front vs. rear for street driving.
Take the rear off for sure, I noticed zero difference
With the fronts off, yeah I mean its a little different, but you just have to adjust your driving style accordingly. I can easily take freeway exit ramps at or above the sign. I've been driving them disconnected for 6 months. There is a 6 page forum post about this over at Expedition portal
Stiffer springs will also reduce the sway.
I'm actually a little more concerned about off-road driving, as on my last outing I had a bit of a scare... felt like I was going to tip. But I think pros outweigh the cons, so off they go!
Old Mar 23, 2018 | 07:27 PM
  #5040
Twix's Avatar
I have no front bar either. Really tight corners even at lower speeds you can feel the roll, but it's not bad. If I try to change lanes really fast, she'll wobble pretty scary like.
