Old May 13, 2019 | 07:00 PM
  #6631
Landy-04's Avatar
I put my new wiper blades on and seem to work fine. Noticed today that if you have the wipers on and go into reverse the rear wiper will do one swipe. Love it!
Old May 13, 2019 | 07:10 PM
  #6632
Best4x4's Avatar
Locally a D2 wiper blade is 21.00 per blade. For basically a 4.00 style plain blade. D1 wise = a ton of brands and types available. To each their own, but all my D2’s except for one = D1 wiper arms.
Old May 13, 2019 | 10:04 PM
  #6633
whowa004's Avatar
Did some weight savings, pulled front sway bar and "cross member" that the driveshaft hits....will pull the rear sway bar later this week.
Old May 14, 2019 | 12:05 AM
  #6634
razorkill12's Avatar
Originally Posted by Best4x4
You have to slightly bend the D1 arms & I’ve had excellent results with Bosch Icon, or any aerodynamic new style wiper blade. The OEM D2 blades are about as good as a 4.00 set of el cheapo’s!
People tend to use 18’s on a D2 with the D1 wiper arm & I guarantee 21’s work & you should use them. Also I’ve heard the aftermarket D1 arms seem to be cheaper vs OEM D1 arms, so go figure. I’ve only used original D1 wiper arms.
This!! I switched to D1 arms years ago when I got my D2. The last couple sets of wiper blades started missing spots......bent wiper arms a little bit and whammo. Problem solved.
Old May 14, 2019 | 09:33 AM
  #6635
Friday Night Disco's Avatar
Concerning the D1 arms and 21" blades, Below is the increase coverage of the blades. Point is, the D2 arms will give you less coverage and D1 arms give you more flexibility.
I did not have the problem of missing spots with my D1 arms, maybe they were already bent to increase the pressure.
D1 21"
D2
Old May 14, 2019 | 12:05 PM
  #6636
Discorama's Avatar
I made the D1 arm mod and can't complain. An additional benefit is to get strong springs with the new arms, which replace the worn out springs. Wipers from Costco work great, and they have them on sale from time to time. I'll try out quality silicon wipers next time, lets see if they last much longer.
Old May 14, 2019 | 12:44 PM
  #6637
JUKE179r's Avatar
To prolong the life of your rubber wiper blades wipe them down with a paper towel soaked with plain white vinegar.
You’ll thank me later...
Old May 14, 2019 | 01:56 PM
  #6638
Richard Gallant's Avatar
Did a test of a 3 process system to clean up my "whisker marks"
Before
After
And how she sits post lift Terrafirma Medium duty all round,, yup springs are blue they were pretty rusty looking, so some Tremclad ford blue I had laying around took care of that
Old May 14, 2019 | 05:19 PM
  #6639
Pavilion's Avatar
Right so finally took the pics. Got both heads done now. Just waiting for the cam and lifters to arrive and Ill put it back together.
Old May 16, 2019 | 04:43 PM
  #6640
Pavilion's Avatar
Got the heads torqued down, new motor mounts on and slipped the block back into the tranny. Im being rushed a bit as I was borrowing the hoist and motor stand. I really hope the cam comes out in the bay or Ill be repeating myself lol.
