Old Jun 23, 2019 | 03:48 PM
  #6761
HuskerRover's Avatar
Bad day. Went about replacing the u-joints on the front prop shaft. After getting the correct u-joints (mine was installed with the 380), I was reinstalling them when I broke the casting for one of the retaining clips. Dammit anyway.
i decided to just order a new shaft from lk8 and be done with it!
Old Jun 23, 2019 | 03:58 PM
  #6762
Landy-04's Avatar
Default Brit part ladder
Installed my Brit part ladder 😎
and I used the dreaded nut serts! For the win!!
Old Jun 24, 2019 | 09:48 PM
  #6763
No Doubt's Avatar
Thought about cutting up my rear hatch to relocate the handle to allow me to mount a spare jerry can there (then I would have moved the license plate to the fuel can base)
Decided instead to mount the extra fuel tank on the spare tire for now.
Has anyone else done this, and if so, what brackets did you use to hold it onto your spare?
Old Jun 28, 2019 | 10:11 AM
  #6764
Brooklyn Rover's Avatar
8th Gear
Default Fuel door latch mechanism and clip.
The fuel door just stopped working a few months back finally got around to ordering the parts and switching them out this morning. Was much easier than I thought thanks to the pertinent posts from the forum.
Old Jun 29, 2019 | 11:17 AM
  #6765
Replaced front prop shaft from LK8 and replaced front diff oil. All fluids now new!
Special thanks to LK8 for an affordable/reasonably priced prop shaft.
Old Jun 29, 2019 | 02:16 PM
  #6766
Best4x4's Avatar
Pulled out a Diesel 2WD Ford Excursion buried up to it's rear doors in mud with my 99 D2.
Old Jun 29, 2019 | 04:09 PM
  #6767
shaneb24's Avatar
Just finished large project...
I replaced my timing chain, water pump, oil pump, power steering pump and all pulleys. Put in fresh liquids and its looking like were in good shape.
Old Jun 30, 2019 | 03:56 AM
  #6768
Landy-04's Avatar
I installed my Ultragauge 😅
Old Jul 2, 2019 | 01:24 PM
  #6769
PJWHEEL's Avatar
4th Gear
Default Hit 68K miles on my 04 SE7
Engine gets hot, but I got a 180 thermostat I need to install. On the iLand it showed temp was ticking up to the point that everyone on here says beware. Only gets hot if I jump in and immediately hit the highway booking it to a plant, or if I sit in park after about 10-15 mins (SC in July). Because of the nature of the cooling system, I just switch the ac to auto or blast it and it comes down after a couple minutes on the road. Never had it hit the red, but once the180 thermo gets in shouldn't be an issue.
I have a small heater core leak, I think... Anyone know if a Freon leak could leave residue on the passenger floorboard? Also I've heard about K-Seal, and the don't do its. Since I have might have a small crack in the core (hoping its just the gasket on the pipe) and will replace the thermostat and hoses, anyone have thoughts on using a small amount of K-Seal for the leak and then flushing the system and replacing the thermo? People say it can block up your heater core, but it's a 50/50 if I have to replace the core anyway.
Old Jul 3, 2019 | 10:21 AM
  #6770
CollieRover's Avatar
Enjoy Hoiball. Going to be cheering for you guys in the Big 10, which is not easy for a Cyclone fan.
