Old Apr 27, 2020 | 08:40 AM
  #7441
DCDisco2's Avatar
Originally Posted by redrover75
Did a smoke test to find my vacuum leak, no leak, but found SAI pump was not plugged in. That thing is loud! Will take it apart, see if I can quiet it down. I don't think I have ever heard one before, in 6+ years of ownership. Now, I have a different set of codes, cleared a few and now I have P1412, P1415, P1884. Not sure why have the transmission fault. Will need to dig into it.
Part of the noisy SAI problem is that it has a non-serviceable filter that has probably completely hardened or disintegrated by now. It's relatively easy to pull the filter cover off, remove what's left of the filter, and replace it with a K&N 62-1370 breather filter that is washable and much quieter. You'll need to grind off the plastic tab that kept the filter away from the intake port, I find a Dremel works well for this.
Old Apr 27, 2020 | 09:00 AM
  #7442
JUKE179r's Avatar
I used a razor blade to cut it off. Works fine.
Old Apr 27, 2020 | 09:03 AM
  #7443
DCDisco2's Avatar
Well I stole the whole idea from you, so you’re certainly the expert.
Old Apr 27, 2020 | 01:29 PM
  #7444
Best4x4's Avatar
Washed the 04 and did a little trail run on the inlaws property.
Old Apr 27, 2020 | 04:19 PM
  #7445
DCDisco2's Avatar
Replaced the unknown aged gear oil in both differentials with fresh Valvoline 75w145 full synthetic. That stuff was black as night and the new oil looked lovely going in. Definitely drives a little smoother, and a really easy job without many tools.
Old Apr 28, 2020 | 01:26 PM
  #7446
No Doubt's Avatar
Old Apr 28, 2020 | 01:50 PM
  #7447
Jason_B's Avatar
With the headliner board removed, I applied some RTV to the sunroof drains, and started adding soundproofing to the roof. I am going to sound proof the entire roof and rear cargo area.
Old Apr 28, 2020 | 02:24 PM
  #7448
The Deputy's Avatar
Drove the white 04 to the Sec of State (MI DOT) to get plates transferred. Made an appointment, since they are closed to all other transactions that can be done online or through the mail. Arrived...and they were closed...period. You'd think they'd have sent me an email stating they were closed...or at least NOT let me make a freak'n appointment.
Anyhow, after being couped up for seven weeks, felt good to get dressed and go for a ride (besides to grocery store). The 04 is a joy to drive, smooth as glass compared to the Defender.
Beautiful day for a ride.
Brian.
Old Apr 28, 2020 | 07:17 PM
  #7449
SASINGSP's Avatar
4th Gear
Default My 04 Disco Got a Face Lift
Replaced the stock front end with the ARB bumper, Warn Winch and KC lights. Very pleased with how it turned out.
Old Apr 28, 2020 | 11:24 PM
  #7450
escott16's Avatar
Finally installed my arb bumper and harbor freight badlands 12000k (ik it’s crap but it was 100$ off and i would use it maybe once a year)
