Old May 20, 2020 | 10:01 AM
  #7541
escott16's Avatar
Originally Posted by JUKE179r
Damn that looks GOOD!!!! Did you clay bar it also?
yes and used their prepping spray
Old May 20, 2020 | 10:30 AM
  #7542
boston4's Avatar
New ball joints! These had developed a terrible squeal whenever I turned the wheel, despite not having any of the clunking symptoms of failing ball joints - it seems like the boots failed and the grease leaked out. In MA, torn or missing boots can cause you to fail inspection, so it wasn't as though I could just shoot some grease in there and live with it.
This is the first item that I've gone to a shop to have done. With no garage or torch, I think this one was a little too ambitious. Had a good experience with the shop and I had them throw on some new brake rotors and pads during reassembly.
Next up:
- Fix AC, install new blower motor
- Install new fuel pump (currently my fuel gauge isn't working correctly)
- Transmission and transfer case fluid change
- Frame repair
Old May 20, 2020 | 06:10 PM
  #7543
mln01's Avatar
I agree with you completely.
I have a garage, and I have a small, propane torch, but I've read too many ball joint horror stories to want to do that job myself. I did the headgaskets myself ten years ago, and there's not much I won't tackle myself, but not ball joints.
I'm curious, please, what were you charged to do the ball joints only, not including the pads and rotors? Are the charges broken out that way? Or even the total less the parts cost for the pads and rotors since there's really no additional labor? Thanks.
Old May 20, 2020 | 06:19 PM
  #7544
boston4's Avatar
Originally Posted by mln01
I agree with you completely. I have a garage, and I have a small, propane torch, but I've read too many ball joint horror stories to want to do that job myself.
I had already purchased the rotors and pads and planned to replace them myself. Then, the ball joints went, and since they were taking the whole front end apart anyway, I just asked that they put on my new brake parts while they were putting it back together. They didn't charge me for this.
Parts (OEM upper and lower ball joints both sides) were about $200 total and labor was about 7.5 hours. I think the uppers had some life left, but I'd have been kicking myself if I only had them do the lowers and then the uppers failed in a year or two.
Old May 20, 2020 | 07:16 PM
  #7545
whowa004's Avatar
Nothing major but went for a nice ride yesterday afternoon and then today found the disco leaking coolant. Thinking pinhole leak in the radiator based on what I could find. Hoses are intact and it’s not coming off front of motor.
Old May 20, 2020 | 07:37 PM
  #7546
redwhitekat's Avatar
Originally Posted by Discorama
Thanks, good to know, otherwise the ARB would be a no-go. Otherwise, is there some wiggle room to install the bumper not too close that I can still get the headlights out?
speak of the devil Of course the passenger head light went out today. Had to replace it. Never fails
Old May 20, 2020 | 07:50 PM
  #7547
arains44's Avatar
After my post yesterday about my 04' Disco throwing a P1176 code I did some hunting on the forum. Found out most folks with this code found lose bolts on the intake plenum. Well, what do ya know - one of the bolts on the plenum was finger tight! Tightened it up along with the rest of the bolts, cleared the code, and now it no longer stumbles at idle and the code has not come back. Cheap fix... Ordered some headlight guards and a LR rubber floor mats to replace the Chevy branded format on the driver's side that the truck came with.
Old May 20, 2020 | 11:54 PM
  #7548
boston4's Avatar
Did you get the Bearmach light covers?
Old May 21, 2020 | 12:50 AM
  #7549
Gripen's Avatar
Had a trusted shop replace the front driver-side hub bearing, CV joint and axle, along with installing a set of Gwyn Lewis 4x4 Products stainless steel Sumo Bars steering bar kit. The Sumo Bars, btw, are hefty. Only way they'll bend is if I do something REALLY stupid. Bought directly from Gwyn Lewis. Shipping was surprisingly fast, considering it had to cross the Atlantic and the US to get to me.
Old May 21, 2020 | 01:01 AM
  #7550
MrValingo's Avatar
Replaced both motor mounts again. Tore the first set back in March and tore the new ones a few weeks ago. Both at the same ohv park. Can't wait for round three next month
