Old Jun 3, 2020 | 07:34 AM
  #7601
redwhitekat's Avatar
Wired brushed the frame and got rid of that old flaky por15
spray painted with black rust paint.
I was bored and live in Canada where snow I’ve and salt will destroy the frame if you don’t look after it.
My neighbour says. Never seen anyone do they , His Chevy is falling apart lol
little beagle help
Old Jun 3, 2020 | 02:59 PM
  #7602
Richard Gallant's Avatar
Replaced my fan clutch the new certainly locks up, but on 1st startup the plastic bleeder screw cracked fine mist of AF everywhere. I have a container of spares grabbed off BMW's, replaced the dead one down to 1 left now.
But getting rid to that is another reason to do the inline thermostat mod.
Let the Disco get up to 186 with A/C at idle brought the RPM up to 1880 ish dropped to 179.1 in about 30 seconds that is an improvement, still needs a road test to close this off.
Old Jun 3, 2020 | 06:21 PM
  #7603
Road tested the Disco back to normal temps 186-194 depending on speed and rpm generally 188.6 ar 70KPH/45 MPH and 2100 rpm 194 floating behind dump trucks at around 1350-1400 55 KPH/ 35 MPH in 4th gear
Pulled the transmission bezel, the **** came up easy, to clean my mode switch. The electrical connections were pretty ugly and I need a new bezel mine has all of one hold down left.
Not mention the 4 tons of crap under there
Old Jun 3, 2020 | 06:51 PM
  #7604
DCDisco2's Avatar
Installed British Atlantic’s trailer wiring kit. Literally plug and play, took 5 minutes, couldn’t be easier. Don’t have anything to tow at the minute, but it’s nice to know that I could.
Old Jun 4, 2020 | 07:30 AM
  #7605
Installed my new guard
Old Jun 4, 2020 | 10:02 AM
  #7606
JUKE179r's Avatar
Originally Posted by Richard Gallant
Hey Rich... my old military "attention to detail" spidey senses noticed the corrosion on those solder joints for the LED shifter lights.
I apologize for being a worry wart. lol
Old Jun 4, 2020 | 12:15 PM
  #7607
@JUKE179r yea there was more than bit, it took a bit a cleaning to get them look good. But my mode switch seems happy again. Finding a new Bezel is going to be a pain though
Old Jun 4, 2020 | 06:00 PM
  #7608
The Deputy's Avatar
Are you able to switch the bolts around, so threaded end is up. If you start banging up those threads on rocks and stuff...you'll have one heck of a time removing.
Old Jun 5, 2020 | 08:13 AM
  #7609
jastutte's Avatar
my thoughts as well.
Old Jun 6, 2020 | 06:40 AM
  #7610
The Deputy's Avatar
Easy day, oil change and lube on the 03, check A/C status, added a half pound...good to go. 04 needs new compressor, have one off my 01, doing the swap...but wife beckoned...so swap came to a stall.
Side note...checked A/C system on Defender...vents open as needed...lol.
Brian.
