#7871
I have used the hella 500 driving lights on several different rigs over the last 20+ years. I have always liked their long distance reach and a nice focused beam in the road ahead, in Colorado i use them driving mountain roads to pick up deer and elk way ahead of time. I have always been happy with them.
this latest set i installed on the disco 2 are crap. Instead if a nicely focused beam they are throwing a donut shaped circle of light. Two huge circles with a dark hole in the beam. So i replaced them today. With new led lighting. Unfortunately made in china, but they seem to be much brighter, 30 degree spot flood combos,
hella
new led
hella
new led
The following 3 users liked this post by baileyrockhound:
#7872
One of my first projects when i bought the disco last month was a new radio, this rig came with the a single din am fm radio no subwoofer.
yesterday i got around to installing new door speakers, these are the mid/woofers out of an mtx component set, the OEM tweeters works fine so I'm still using those
#7873
I fabricated new 1.5 inch spacers for the front crossmember when the 3 inch lift went on, at the time I had plenty of space between the two.
after I corrected the caster in the front axle I noticed the driveshaft was making contact
with the crossmember when on the lift, both sides of the axle off the ground. I flexed the rig out on the shop and it seemed to have room under normal conditions, but having the shaft bound up everytime I changed the oil does not please me either.
I made a quick adjustment to the crossmember. Not sure if this method works for other lifts. Bear in mind I already had installed the spacers and have a crossmember that can be removed easily with new hardware etc.
Richard Gallant (10-31-2020)
#7874
You know when your........
I am not trying to push the OCD (CDO) issues with wiring and making sure we are good but crap, I should have been done a month ago....
So, I am still making sure all the relays, wiring, lights and my OCD will be perfect. As I go through the Rover I am finding the bull**** that was done to sell this baby gurl fast.
Then there is then **** I want to put on.
So here we go, I am seeing different comments about the thermostat and how to keep the engine cooler. I have seen this picture and others on here saying this works the best, but also seeing people using this and keeping the original thermostat but putting it near the radiator.
So what is the best answer?
How do I keep from draining the battery after I am following the directions on wiring properly? Add another battery, get a stronger cranking alternator, crying, get those optima battery?
Still looking for someone and group in the Eastbay area of Oakland to meet up and have coffee or just find a good set of friends.... Non Stalkerish......
#7875
jastutte (10-31-2020)
#7876
Leds
Which leds did you get? I got a set of 140k lumens that leave much to be desired.
hella
new led
hella
new led
#7877
#7878
I finally fixed my two leaky sunroofs. I installed new 3D printed hose connectors, used 3M Marine sealant between the frames and the roofs as well as the glass bolts, and installed new rubber gaskets. While I had it apart I decided to add sound-heat insulation to the roof and redo the headliner with some material I picked up on vacation in Hawaii last year. Now everyday driving the truck reminds me of the islands
#7879
ckadventure (11-22-2020)
