Old Jun 6, 2021 | 08:57 AM
  #8211
mollusc's Avatar
Originally Posted by mln01
I know The Deputy is a seasoned mechanic, but for many others of you out there, be very careful adding refrigerant. Too much in the system can lock up the compressor and cause other problems, like the serp belt getting fried as it passes over the non-moving A/C pulley. Not that I ever did that ...
Or you could unknowingly overpressurise the system and be sitting in a drive-through when the relief valve blows, dumping the whole system in a huge cloud in a single second, coating your entire engine bay with indicator oil.
Old Jun 6, 2021 | 03:16 PM
  #8212
The Deputy's Avatar
Most of the parts store kits have a gauge, green/low on freon, blue/fill range, red or yellow/over charged or compressor issue. Best to have a A/C thermometer and stick it in center vent, A/C on lowest setting, blower on high, windows up/in shade and recirculation button pushed. Make note of ambient temperature/humidity level and shoot for about 30/35 degrees below that. Watch gauge, staying in blue range and watch thermometer. If 85°...55°/50° out of the vent on a stationary vehicle would be acceptable. Vent temps will most likely be lower, once vehicle has more air moving across condenser. R134a doesn't like being overfilled, you will see temps drop if system receives to much freon.
Yes, caution should always be used...while doing A/C charging. And repairs should be done by a MAC certified shop or mechanic. Or if you have any doubts at all about your skill level...have a professional make repairs or recharge system.
Old Jun 6, 2021 | 05:18 PM
  #8213
redwhitekat's Avatar
Bypassed my throttle body heater today
tomorrow I will coat the inside of my frame with the eaton product frame coating
Old Jun 7, 2021 | 05:39 AM
  #8214
JUKE179r's Avatar
With everyone talking about recharging their low pressure AC line I went ahead and bought this to try out…
I’m going to do a before and after temp check.
Old Jun 7, 2021 | 12:55 PM
  #8215
kdscott100's Avatar
Nice rig, especially with the matching canine.
Old Jun 7, 2021 | 05:11 PM
  #8216
Wrapped my cps sensor cover with aluminum foil. Pain to get the bolts back in
drove the new rover about 400 miles today
temps never got past 190 and it’s 30 Celsius here ac on for the dogs.
So far I don’t see any major issues.
new drive shaft arriving this week
Old Jun 8, 2021 | 09:18 AM
  #8217
whowa004's Avatar
Got the white one out for a little off-roading on Saturday with a couple of buddies and their RRC. I was at the end of the group and I don't think anyone took any photos unfortunately. Truck ran well and so far has been performing nicely since the hg and cam swap.
Green one will be running today, just need to throw coils, upper intake and repipe coolant lines. then fluids and time to crank
Edit: I snapped one while airing back up.
Old Jun 8, 2021 | 11:19 AM
  #8218
Richard Gallant's Avatar
Cursed the stupid rad cap, collapsed rad hose - thermostat to T. It really needs to stop raining so I can get Extinct's mod in place. At least I have a spare.
Old Jun 8, 2021 | 11:36 AM
  #8219
whats wrong with the rad cap ?
Old Jun 8, 2021 | 11:37 AM
  #8220
Harvlr's Avatar
If you would go 3 hours east, we’re praying for rain
