Old Nov 27, 2021 | 06:02 PM
  #8561
cvhyatt's Avatar
Originally Posted by Extinct
Generally, no, although some guys have had bad radiators out of the box. Very rare, maybe two that I know of based on helping people with their cooling problems over the last couple of years (several hundred inline installations and follow up assistance). More likely your thermostat is not functioning ideally, I have several working factory thermostats (I think one is brand new never been used) I can send for the cost of shipping but obviously I recommend the inline mod. Several users down in your part of the world can give you their feedback but generally you should be seeing 100 degrees + ambient as operating temperature.
Hey Extinct - I was looking at purchasing off your website but it said the config was unavailable.
Old Nov 27, 2021 | 06:35 PM
  #8562
Extinct's Avatar
Sorry, we had an inventory error but it should be corrected now, let me know via pm if it is not working now.
Old Nov 27, 2021 | 09:13 PM
  #8563
cvhyatt's Avatar
No problem. Order placed!
Old Nov 28, 2021 | 08:08 AM
  #8564
Alex_M's Avatar
Had a little fabrication job for a customer this weekend. He wanted some lights added, so I built a hoop to go on his Terrafirma bumper and mounted up a couple Hella 500FFs.
The LEDs underneath were a n addition from a prior visit.
Tapped threads for the ground right into the mounting tabs.
Threads are tapped into the bumper, no nuts required. Makes for easy removal/reassembly if it's necessary.
Also fed the wires through the inside of the tube to keep everything tidy.
Super pleased with the look and function. This was a fun little project.
All stainless hardware was used so there won't be any corrosion issues. The mounting plates and tabs are 1/4". You could jack the whole front of the truck up off this bar, it's very strong. Should provide some protection from deer in addition to being the mounting for the lights. It may bend in an impact with a deer, but should also protect the truck and be easily replaced since it's bolt on.
Old Nov 28, 2021 | 09:21 AM
  #8565
dtmbinb's Avatar
Nice work! Love to see a great Disco in VA!
Old Nov 29, 2021 | 06:41 AM
  #8566
redrover75's Avatar
Went to flush the differentials yesterday, one of the last warm weather days we should have. The fluid was crystal clean, green, must have been done by the PO, 3.5 yrs ago. A bit disappointed, but I suppose I dont need to do the rear. I have the brass plugs and everything. I have run out of things to fix, even the PS pump stopped leaking.
knock on wood.
Old Nov 29, 2021 | 02:27 PM
  #8567
Harvlr's Avatar
Way to go! I’ve never quite run out of things to fix or maintain.
Old Nov 29, 2021 | 07:44 PM
  #8568
cvhyatt's Avatar
knock on wood.
Old Dec 1, 2021 | 05:41 PM
  #8569
redrover75's Avatar
Well, my P1415 came back. I can clear it for a day, but then it comes back.
When I replaced the BMW sai valve, not the Hyundai one, there was residual vacuum, negative pressure, on the vacuum line. Should that be there? Or, should the system be neutral pressure at rest?
That may be my issue I hope.
Old Dec 1, 2021 | 06:49 PM
  #8570
Extinct's Avatar
Check it without the valve plugged in, unplugged there should be no vacuum downstream.
