Old Mar 21, 2023 | 01:31 PM
  #9211
wjsj69's Avatar
Originally Posted by jastutte
The one that just failed was fully greaseable and, i think, failed at the transfer case side. I dropped it at a Driveshaft shop this morning to see if it can be rebuilt. They'll let me know where it failed.
Being greaseable (and you kept up with it) It should last indefinitely. They are also fully rebuildable. And it may not have completely failed, just dry. If you greased it before you took it off, it may have been fine. I keep a mini grease gun in the truck for this reason. The hardest part is getting to the centering ball with a needle fitting. Maybe that's the squeeky part, but a shop may not tell you the culprit, they'll probably just gut it, and reassemble with new parts. If you're depending on a shop to keep it greased, this could be why you're going through them..
Old Mar 21, 2023 | 06:53 PM
  #9212
mln01's Avatar
Redrover doesn't get out much any more, and less often gets out of town, but last weekend I took Redrover for a Scouting Camporee about 90 miles from home. I lead the organizing group, so there were a lot of things I needed to take that would not have fit in the Accord.
I know a 180 mile roundtrip is no big deal, but when I stopped on the side of the road out in the quiet country with no radio on I was struck by just how quiet and smooth the engine was. And no, I hadn't shut it off! No Amigos and no SRS light, plus a consistent 188.6°. What a pleasure it is to drive this truck. Just shy of 180,000 miles and running strong. I've owned it since May 2002 when I bought it with ~21,500 miles, and I've done all maintenance and repairs since the fall of 2009.
The title of this thread is "What did you do with your DII today?" Most often it is more of a what did you do TO your truck. I just wanted to share a pleasant experience with my DII.
Old Mar 22, 2023 | 06:12 AM
  #9213
Extinct's Avatar
This really is the truth. I remove the DS every oil change and grease it on the bench. Make sure I hit the centering ball. 237k on the truck, I rebuilt the ds myself shorting after we acquired it with 180k on it. When I took it off last week it was in fine shape.
Old Mar 22, 2023 | 02:51 PM
  #9214
jastutte's Avatar
I got the rebuilt driveshaft back today. It failed due to no grease on the centering ball.
sigh. Really wish I could trust my otherwise competent shop to properly grease these things.
Headed outside to install the rebuilt driveshaft now.
Old Mar 22, 2023 | 03:56 PM
  #9215
wjsj69's Avatar
At least you figured it out before it exploded and took out the trans! Crisis averted
Old Mar 22, 2023 | 09:40 PM
  #9216
andino's Avatar
Headlights were getting a little foggy again so I did a quick polish on the car. Need to take them off and do them proper followed with a sealant so they don't fog up again. Also need to install my synthetic line and new fairlead and fix that bent one LOL. A never ending list of tasks for this one.
Old Mar 23, 2023 | 02:28 PM
  #9217
Discorama's Avatar
I did you seal the headlights? I tried with silicon but that didn't last long. I probably need to put them into the oven, rip the lens off and seal them with new headlight seal properly.
Old Mar 23, 2023 | 04:20 PM
  #9218
andino's Avatar
I haven't disassembled them that far but I'm planning to do a retrofit sometime this year. I just meant I need to seal the plastic lenses because I polished them and they'll turn yellow if I don't finish them with a UV stable spray.
If you took yours apart, I'd recommend some butyl to keep it from leaking.
Old Mar 23, 2023 | 04:23 PM
  #9219
whowa004's Avatar
Originally Posted by Discorama
I did you seal the headlights? I tried with silicon but that didn't last long. I probably need to put them into the oven, rip the lens off and seal them with new headliner seal properly.
pull them apart and redo the seal. Theretrofit source sells the gasket material as you might as well do an HID projector retrofit if you're pulling them apart imo.
Old Mar 23, 2023 | 09:23 PM
  #9220
Discorama's Avatar
Did you put them into the oven for that? I am very afraid of that.
