What's wrong with my Disco??
Old Jun 11, 2014 | 07:29 AM
Richard Moss's Avatar
Originally Posted by Disco Mike
By the way, how mechanical are you?
Well I don't know about him but although I have a mechanical heart valve, the rest of me is human
Old Jun 23, 2014 | 02:46 PM
wilsbrass's Avatar
6th Gear
Ok Question for you guys.
I found the problem to be the tie rod ends.
Now, can I just buy the 2 tie rod ends or do I have to buy The Track Rod complete?
Do both tie rod ends screw in or does the Track rod has one side welded in?
Old Jun 23, 2014 | 02:49 PM
wilsbrass's Avatar
6th Gear
The side that has the steering damper (where it screws in on the driver side left front tire) looks like is welded to the track rod???
Old Jun 23, 2014 | 03:03 PM
OffroadFrance's Avatar
One end is crimped permanently onto both the drag link and tie rod. Unless you are lucky and the end that's shot is the end which unscrews you have to buy the complete rods respectively. However, if the end that is shot is the unscrewable end be certain that the fixed end won't be far behind and will need replacing soon. It'll work out cheaper to buy the whole rod than in two parts later. (this is just another LR cheapo engineering get out as most rods are adjustable both ends.)
Old Jun 23, 2014 | 03:31 PM
dusty1's Avatar
it is usually a better option, to go with an upgraded aftermarket set. oem = $$$
I have
from rn TERRAFIRMA, TF255, STEERING ROD DISCOVERY 2, DISCO II - Rovers North - Classic Land Rover Parts
l8 has them and others too
Old Jun 23, 2014 | 05:39 PM
Totally agree Dusty. And the ball joints are screwed in at BOTH ends and adjustable. They are also universal for LHD and RHD but the only thing that makes me slightly nervous is the steering damper bracket is held on with 2x U bolts and not welded. Maybe I'm just being paranoid
Old Jun 23, 2014 | 10:27 PM
wilsbrass's Avatar
6th Gear
Thanks guys I ordered the parts I will let you know how it goes.
Old Jun 23, 2014 | 11:51 PM
dusty1's Avatar
That bothered me, as well. 2 rough years later....So far so good.
punkarockaboy
Aug 30, 2011 04:27 AM
punkarockaboy
Aug 23, 2011 07:43 PM
Bryan H
Dec 12, 2009 12:41 PM
Disco.Jay
Mar 4, 2006 09:08 PM
angelinajolie
Dec 21, 2005 10:31 PM
