Window seals
`The seal on the back windows of the cargo area are all dried up and cracking I cant seem to find replacements. Any place that y'all know of, and how hard are they to replace.
Thanks
Walter
Thanks
Walter
you need to get them at the dealer. They run about $60 for the rear and $50 for each of the side cargo window seals. I bought mine about a year ago and just had them replaced last Friday. Cost me $100 to replace all three seals. Mine had cracked in most of the corners, looked bad, didn't leak however. one of the side seals was really tight and didn't go in all that well. I called the dealer and they told me that the seals were guaranted and that they would happily swap it out for another one. One of the side seals was in a black bag and the other was in a clear bag. The one in the black bag had a wax-like substance on it. Was a pain in the tail to get it off. The seal itself however fits very well. The rear seal also fits really well. Good luck. Phil
I have the exact same problem on my '96 D1. The seals are cracked in the corners. They also tend to bleed black onto my white paint when I wash it. I'd like to replace them myself if it's not too hard. Any instructions or pictures would be fantastic. TIA.
RH PART # AWR5388G $52.95
LH PART # AWR5389G $49.95 Atlantic British( www.roverparts.com)
not an impossible job to diy, but most glass shops will only charge you $50-60 to do the work....usuallly while you wait.
see the rave manual there is a glass section with step by step instructions.
