Window seals
Old Mar 11, 2010 | 09:01 PM
aemnky606's Avatar
Default Window seals
`The seal on the back windows of the cargo area are all dried up and cracking I cant seem to find replacements. Any place that y'all know of, and how hard are they to replace.
Thanks
Walter
Old Mar 11, 2010 | 09:04 PM
hilltoppersx's Avatar
find someone parting out a newer disco 1 look for a 98 or a 99 nearby.
Old Mar 12, 2010 | 01:02 AM
ljdiscovery's Avatar
you need to get them at the dealer. They run about $60 for the rear and $50 for each of the side cargo window seals. I bought mine about a year ago and just had them replaced last Friday. Cost me $100 to replace all three seals. Mine had cracked in most of the corners, looked bad, didn't leak however. one of the side seals was really tight and didn't go in all that well. I called the dealer and they told me that the seals were guaranted and that they would happily swap it out for another one. One of the side seals was in a black bag and the other was in a clear bag. The one in the black bag had a wax-like substance on it. Was a pain in the tail to get it off. The seal itself however fits very well. The rear seal also fits really well. Good luck. Phil
Old Mar 12, 2010 | 05:38 AM
antichrist's Avatar
I got mine from DAP.
They aren't that hard to install.
I'm working on photo documentation on installing them.
Old Mar 12, 2010 | 06:49 AM
DiscoJag's Avatar
Thumbs up
I have the exact same problem on my '96 D1. The seals are cracked in the corners. They also tend to bleed black onto my white paint when I wash it. I'd like to replace them myself if it's not too hard. Any instructions or pictures would be fantastic. TIA.
Old Mar 12, 2010 | 08:09 AM
XCELLER8's Avatar
RH PART # AWR5388G $52.95
LH PART # AWR5389G $49.95 Atlantic British( www.roverparts.com)
not an impossible job to diy, but most glass shops will only charge you $50-60 to do the work....usuallly while you wait.
Old Mar 12, 2010 | 08:14 AM
see the rave manual there is a glass section with step by step instructions.
DiscoRom
Nov 2, 2009 11:52 PM
jigray3
Sep 4, 2009 09:15 AM
98roverguy
Sep 20, 2008 07:25 AM
ljdiscovery
May 22, 2008 10:30 AM
Benhamtroll
Jun 6, 2005 03:49 PM
