Discovery 2 LS Conversion
#1071
Very exciting. I would definitely be in favor of running a GM alternator vs one made by Land Rover. Does anyone know the difference in amperage the GM alternators are capable of vs the stock discovery?
I believe CaptainAaron upgraded his alternator to one from the Range Rover because it had a higher output?
#1072
Factory LR Disco alternator is 130A. I upgraded to the 150A unit from the 99-02 P38 Range Rover, which fits with no mods.
losinov (09-30-2021)
#1073
#1074
#1076
LS Swap Wiring Assistance
Hi All,
New to posting to the forum but have been following this thread for over a year now. I have undertaken he ACE conversion LS Swap and have run into a head scratcher that I'm hoping someone can provide a bit of guidance to me.
Bit of information on the build to aid in providing responses:
Photo below shows the connections off of the transmission
Photo below shows the connectors that remain to be connected but none appear to be correct for the transmission
Would greatly appreciate any guidance from the guys that have completed the LS swap and have their rigs running.
Thanks,
Rob
- 2004 Disco 2 SE
- 2004 LM$ as donor motor for heart transplant
- ACE Conversion Kit used
- ACE modified original rover harness
- PSI LS harness per the ACE Specifications
- PSI Red/Blue ECU per the ACE Specifications
Thanks,
Rob
#1077
Leave the circular Land Rover connection in the transmission. The two square black connectors go in the transfer case - I think they are a temp probe. They need to be reconnected.
For the PSI harness connectors in the picture in the front of the engine:
I can’t really tell for sure - Read the PSI manual to figure out what they are. There is a diagram in the beginning. I think the orange one is alternator, so that one is unused. I think the green one may be the MAF, so that will be plugged in later. One of the two two-wire ones is the VSS. The VSS has to be cut and wired to the ECB box. VSS connector should have one green and one purple wire.
Of the circle bundle of wires, you need a couple. There is a table in the back of the PSI manual that tells you what is what. See the ACE connection guide to see what to splice.
#1078
For the connections in the trans:
Thank you for the reply. I have now gone through and labeled the connectors on the PSI Harness and now understand what I am working with. I will hopefully get a bit more time this week to work on the final connections.
I have looked all over the transfer case and there are no connection points for the two black connectors, These were originally connected to the Disco harness that i sent to ACE for modification and what was returned from ACE no longer has a connection point to attach these to so i am truly stumped on these.
#1079
Captain Aaron,
