Steering problem
Old Jul 28, 2010 | 03:49 PM
nickey's Avatar
4th Gear
Red face Steering problem
Hi,
When I drive my RR P38 above 80 the there is a violent vibration on the steering wheel. I have recently changed the steering damper thinking this was the cause but I have the same problem. Can anyone explain what could be the cause?
Thanks
Nickey
Old Jul 28, 2010 | 04:00 PM
britishracinggreen's Avatar
You're driving a p38 range rover over 80 mph, that's why!
Old Jul 28, 2010 | 06:15 PM
wilson96rr's Avatar
Tires? Mine used to vibrate at higher speeds. I got new tires and now it rides nice and smooth. It does still shake a little at 135. jk.
Old Jul 28, 2010 | 09:01 PM
LRScott's Avatar
Your bushings could be on the way out. I would start with making sure the tires are inflated correctly and that the tires are rotated regularly. Check for uneven wear as well as getting the front end re-aligned.
Old Jul 29, 2010 | 01:38 PM
nickey's Avatar
4th Gear
Sorry! I meant 80kph not 80mph.
Nickey
Old Jul 29, 2010 | 01:42 PM
nickey's Avatar
4th Gear
Hi to All,
Thanks for your quick responses. I'll take the advoices.
Regards,
Nickey
Old Jul 29, 2010 | 04:51 PM
gsd2004's Avatar
I don't think it should do that, I had mine at 90MPH the other day and it was smooth as silk!
Old Jul 31, 2010 | 11:31 PM
handsome rob's Avatar
It could be the tires or also the tie rod ends, they do go bad and most people overlook them when doing routine upkeep. You may also have a losse steering gear box but I am willing to bet on one of the other two first.
Old Aug 1, 2010 | 12:26 PM
lrgntgh's Avatar
Default steering vibration
I was experiencing the exact same problem. Seemed as though magically at about 45mph all hell would break loose. My RR certified mechanic gave me a grocery list of things that can cause that. Those included, worn tie rods, worn ball joints, bad tires, bad wheel hub, steering box adjustment, and even a universal joint. If the air suspension has been converted to coils, it can change the pitch,camber of the entire vehicle, which makes the U-joint wear out very quickly.
In my case, the left wheel hub was worn giving it a not so pleasant shimmy. After it was replaced, I got new tires and it rides like a new vehicle.
johnkbl
Sep 21, 2023 06:17 AM
JoMar
Jun 26, 2013 06:20 PM
jycsalas
Apr 17, 2009 02:21 AM
The Image
Jan 5, 2008 05:43 PM
Evian
Aug 18, 2005 11:34 PM
