Sponsored by: CARiD
2002 Discovery II will crank but not turn over:/
Old Jun 13, 2017 | 05:08 PM
bombatape's Avatar
Default 2002 Discovery II will crank but not turn over:/
i have a 2002 Land Rover Discovery II. Background, bought the car last year. never had issues starting until 3 weeks ago. it started taking longer to turn over. finally it seemed like the battery died. went to open the hood and there was a ton of blue spooge coming from the battery.so the i thought it was the battery giving me the issue.. cleaned terminals, got a new battery and tried my luck at that. no dice. took forever to turn over. even longer than before. but it would turn over.
Now, it doesnt turn over unless i mash the gas a lil with cranking it. One of my friends had the same issue and said to clean out the idle air control valve because they can get stuck and gunked up. that didnt work either...when i get it to turn over. it sounds normal and drives normal. but its a pain in the butt to start it this way evertime. need the fix. thanks ladies and gents!
side note:
I had codes:
-p1300: ?z???
-P0134: O2 sensor circuit no activity
-p0442-small leak in evaporative emmisions system
-p0308: cylinder 8 misfire
-p0302: cylinder 2 misfire
Old Jun 14, 2017 | 07:39 AM
MyLandLover's Avatar
7th Gear
I had a problem once, where it was randomly starting, also it shut down while driving, and it turned out to be the Crankshaft Position sensor. Oil had leaked into it and was messing with the signal for the engine firing. It is easy to take out.
At first, I though the fuel line was blocked, since it was starting up and then shutting down.
Old Jun 14, 2017 | 07:49 AM
ftlbritish's Avatar
X2 on the crank sensor. Does your scanner have live data? Check the tooth count.
Old Jun 14, 2017 | 05:15 PM
bombatape's Avatar
thanks guys! ill check it out on my day off for sure! also, i think my friend that had the scanner/code reader does have live data. ill have to check out with him.
Old Jun 16, 2017 | 09:49 AM
bombatape's Avatar
UPDATE: went ahead and changed my plugs. car started right up. have wires on the way. gonna spend a day putting those on lol.
za105
Mar 22, 2016 10:28 AM
ukwildcats
Oct 11, 2015 03:55 PM
sblankenbehler
Mar 30, 2015 06:42 PM
nosup4u
Jun 16, 2014 02:54 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
