Sponsored by: CARiD
2002 Land Rover Disco 2 - Hesitating
Old May 14, 2019 | 08:09 PM
Darrin McGillis's Avatar
7th Gear
Default 2002 Land Rover Disco 2 - Hesitating
Replaced the fuel pump and the idle control sensor ....
No codes have come up now. Seems to be idling nicely
but under load accelerating up a hill it still seems to hesitate and be cutting out a bit .
When you stop on it , it will sometimes cut out then it ok.
Doesnt seem to be running at full power.
Not sure where to go from here with no codes.
The only things I haven’t changed are the injectors, crank sensor and camshaft sensor .
Old May 15, 2019 | 01:54 AM
JUKE179r's Avatar
Dirty air filter? Possibly bad fuel?
You don't have any codes but disconnect the MAF sensor and drive your Disco. See if that changes anything.
Old May 16, 2019 | 02:53 PM
7th Gear
The air filter is clean and MAF sensor was just changed out to a new Beck Arnley insert ...
Almost like it’s starving for fuel but the pump was just changed out.
Josh Matthew
Feb 9, 2016 08:54 PM
Roving-panzer
Jun 4, 2014 08:35 AM
baddiscoII
May 22, 2009 08:06 AM
rirover
Jul 5, 2006 11:21 AM
