2002 Land Rover Disco 2 - Hesitating
Replaced the fuel pump and the idle control sensor ....
No codes have come up now. Seems to be idling nicely
but under load accelerating up a hill it still seems to hesitate and be cutting out a bit .
When you stop on it , it will sometimes cut out then it ok.
Doesnt seem to be running at full power.
Not sure where to go from here with no codes.
The only things I haven’t changed are the injectors, crank sensor and camshaft sensor .
Dirty air filter? Possibly bad fuel?
You don't have any codes but disconnect the MAF sensor and drive your Disco. See if that changes anything.
bcolins
Aug 31, 2008 07:51 PM
