Sponsored by: CARiD
97 Disco stater replacement
Old Jan 19, 2014 | 05:57 PM
demson's Avatar
Default 97 Disco stater replacement
first of all being just a weekend warrior mechanic, should I even be attempting to replace starter on my 97 Disco ? And lets say I could reach the bolts on top which I cannot see as of yet, what are they Allen heads?
Old Jan 19, 2014 | 09:13 PM
abran's Avatar
Yes, Allen heads.
I would suggest using a small pick to clean out all of the crud in the Allen head to make sure that the tool fits into the bottom of the bolt so you don't strip it.
There is a "knock sensor" above the heat shield. You should disconnect it to make sure you don't break the sensor. I just finished mine. I'm a weekend warrior, it took me around 4 hours.
Check the D1 tech section, there is a good write up.
Good luck.
Old Jan 20, 2014 | 08:18 PM
demson's Avatar
Default who's the idiot that decided an Allen head should hold the starter
cannot get lower starter bolt loosened. Any suggestions besides drilling? Is it 8mm or 5/16?
Old Jan 20, 2014 | 10:58 PM
abran's Avatar
Lower is the easiest. I think it's 5/16, but can't confirm. Put an extension on it. Make sure the Allen head is fully seated, and wrench on it.
You might need a wobble socket to get it at a slight angle.
It will come. I had issues too.
Old Jan 21, 2014 | 06:01 AM
fishEH's Avatar
I'd recommend getting the heat shield out of the way first. Cut it, rip it, manhandle it. Just get it out of there and I wouldn't worry about reinstalling it. This should grant you much better access to the socket cap screws. Use an 8mm. Spray some PB Blaster on there and/or some heat with a torch, after you get the wires our of the way that is. Once the starter is out replace the socket cap screws with regular hex head screws.
bennyb43
Nov 28, 2015 04:01 PM
NHxj4x4
Jun 4, 2006 12:00 AM
RobFrey1
Sep 22, 2005 02:12 AM
Shabber
Mar 28, 2005 11:59 PM
chemeguy
Mar 11, 2005 11:35 PM
