Sponsored by: CARiD
Engine Swap
Old Nov 29, 2011 | 06:42 PM
FrFghtrBRET's Avatar
Default Engine Swap
I just put in a new engine in my 2002 LR Disco II, and everything hooked up perfectly, but I can't get the engine to turn over with the key in the ignition. I know the starter is good because I jumped the starter and it turned over. When I tried to turn it over with the key, I got no results. Is there something that has to be reset, possibly with the factiry anti-theft system? Any help would be appreciated because at this point, I am lost.
-Bret
Old Nov 29, 2011 | 07:26 PM
Reset the inertia switch on the fire wall, black rubber button, press it.
If that does not work then reset the alarm, key in the drivers door, lock/unlock 3 times.
Old Nov 29, 2011 | 08:10 PM
Any chance someone removed the starter relay from underhood fuse box for testing / safety reasons... RAVE drawing attached
File Type: pdf
Old Dec 1, 2011 | 09:55 AM
Thanks for the suggestions spike. Neither of the two worked out for me though. It still wont turn over with the key, and it wont come out of park. Any chance that has something to do with the fact that the tow yard towed the Disco about 10yards while it was in Park because they couldnt get into it? Side note..... I found the inertia switch hanging from its wires. The bracket had been broken during engine removal/installation. I used zip ties to strap it back in place thinking that it might think the vehicle had been rolled over.
Old Dec 1, 2011 | 10:01 AM
Savannna, Im no good at reading a schematic but I know for a fact that I didnt remove any relays.????
Old Dec 1, 2011 | 09:03 PM
Um, yeah, I'd say the tow company needs to get it fixed at their expense.
They broke something, hell, it may not even be in park.
Old Jan 14, 2012 | 09:45 AM
roverbob's Avatar
did you remove the transmission in the process of swapping engines?
anyone know if it's possible to do an engine swap without removing gearboxes?
Old Jan 14, 2012 | 06:29 PM
Yes you can swap engines without swapping transmissions.
bennyb43
Dec 11, 2013 08:17 AM
double R
Engine & Internal
Nov 9, 2007 12:50 AM
RJADM2000
Mar 3, 2007 02:06 PM
xb70valkarye
Sep 22, 2006 10:45 AM
Justin
Feb 11, 2005 01:55 AM
