Diagnostic Code p0458 Purge Valve
Old Jul 22, 2022 | 12:09 PM
  #31
flybd5's Avatar
Originally Posted by 4TireFire
the first thing I would check is your battery. Have it tested and fully charged, or replace it if it fails the test. Any auto parts store can do that for you.
Old Jul 22, 2022 | 06:49 PM
  #32
4TireFire's Avatar
New battery was the first thing we did
Old Jul 22, 2022 | 06:54 PM
  #33
4TireFire's Avatar
The codes keep saying purge valve.it is P0458 So I am replacing the effing purge vale. My question to the entire world is, Can a purge valve fail on a Land Rover / Volvo 3.2 cause it to go to limp mode? NOONE can answer the question. Its ok, I will change it and report back so I will be the first in the univeeeeerserve with this solution.
Old Jul 22, 2022 | 07:08 PM
  #34
flybd5's Avatar
Check behind the glove compartment for water/moisture-damaged or loose connectors.
Old Jul 23, 2022 | 05:01 PM
  #35
4TireFire's Avatar
Im going to pull all the carpet back and take the glovebox out and really get in there and look harder, it just all seems tight, doesnt look like a flood victim or leaky junk, this little thing is pretty well kept.
  #36
4TireFire's Avatar
Im digging deep, I cant find anything suspect in the harness. It seems like something is getting hot and cannot recover until i reset the codes and leave the battery unhooked for a while. I drove it over 10 miles and it ran like a champ, stopped at home for an hour and tried to get back in and go, thats when I took the vid, it was in limp mode.
Old Jul 23, 2022 | 05:03 PM
  #37
flybd5's Avatar
Ok. I'm just trying to work through what would make the error code list light up like a xmas tree.
Meldav32
May 6, 2018 02:58 PM
buick215
Dec 7, 2015 10:58 AM
CRB357
May 13, 2015 01:54 PM
toofaroffroad
Oct 24, 2014 07:28 PM
Rover Chris
Feb 13, 2011 09:45 PM
