Aircondition compressor off and on
Old Jun 20, 2012 | 10:53 AM
Quophi's Avatar
5th Gear
Default Aircondition compressor off and on
Hi Guys
I just got the fully loaded 2008 Disco 3 with the 2.7 diesel engine. i was having some non cooling aircon problems, turned out to be a leaking aluminium pipe on the back AC. this is now fixed. three days after driving around, i am noticing the cool air sometimes stops flowing even though the blower is working. kind of like the compressor going off. then it will come on by itself after a few mins, or if i turn the temperature dial down further . any ideas on what is causing this off and on ?
Old Jun 20, 2012 | 12:10 PM
Improper refrigerant (freon) level. Will need a shop that handles AC, has gauges, etc. This is a clutchless compressor that is more complex than the old Detroit models. Pages attached from LR3 manual that can be found on line if you look around.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 20, 2012 | 01:12 PM
wheelgarage's Avatar
Do you know what caused that problem in the pipe?
I am looking in to a used LR3 and need to understand all the know issues...
Thanks!
Old Jun 26, 2012 | 06:43 AM
Quophi's Avatar
5th Gear
Default Solenoid valve
Hi Savannah
thanks for your detailed guides. i am told what is causing the problem is the solenoid valve. is this part replaceable ? i am told there are some gears in there that might be bad. so when i put the AC on sometimes the compressor comes on and sometimes not. or compressor will be blowing cool air for some time and go off with the blower still functioning. you will have to turn the AC off for a while and turn it back on again to bring the compressor back on
Old Jun 26, 2012 | 07:15 AM
Quophi's Avatar
5th Gear
Thanks!
no idea it was an aluminum pipe near the back left tyre
jtherien53
Apr 30, 2021 08:26 AM
kfx4001442
Jun 11, 2013 11:45 AM
lrover2
Jul 18, 2012 07:30 AM
LR03NJ
Jun 10, 2010 04:50 PM
DiscoGravy
Oct 1, 2005 08:22 PM
