Drivers window
Old Dec 26, 2013 | 09:49 AM
jerdog53's Avatar
Default Drivers window
The drivers door window recently stopped going all the way to the top. I was noticing more and more wind noise and so after a short investigation I see the window doesn't go all the way to the top stopping about .25". I can grasp the window and slide it up the rest of the way but it won't stay there and slides back down.
IS there an adjustment to the electric mechanism for play or is the mechanism on its way out and will need replaced with a new $500 part?
How is the door panel held on? A thousand plastic clips like other cars half of which will brake upon removal or some other means?
Thanks
Old Dec 26, 2013 | 09:57 AM
mirepoixmatt's Avatar
This chap w walk you through it.
Old Dec 26, 2013 | 09:59 AM
https://ws.cubby.com/p/_fea250a57119....pdf/257412366
And cubby link.
Old Dec 27, 2013 | 11:07 AM
jerdog53's Avatar
Thanks for that!
I forget to look at You Tube for instructions like this.
So then does this mean I will have to replace the regulator?
Old Dec 27, 2013 | 02:08 PM
Ya know I'm not too sure honestly. If it's going up half way, it would imply to me it's mechanical and not electrical (failed motor) but I could be wrong.I think once you're in there you'll see exactly what it's doing.
Old Dec 28, 2013 | 10:02 AM
jerdog53's Avatar
yah and I was hoping not to take it apart twice
Old Dec 28, 2013 | 02:53 PM
thorgal's Avatar
Before you start taking stuff apart,you should try window motor re calibrating procedure.If you have a auto feature and I am sure you do, there is a sequence that one should follow if window stops going all the way to the top.I can't find it , although, I had it written on piece of paper somewhere, anyway, you should ask for it on british forum, they should answer your Q. pretty quickly.Your problem could be that simple . Good luck
twoxred
Oct 4, 2021 07:07 AM
baysiderover
Oct 28, 2008 08:06 AM
PIROLOGISTS
May 25, 2008 05:43 PM
lionel
Oct 15, 2007 10:53 AM
bruxros
Aug 5, 2005 01:54 PM
