Leaking Mechatronics Sleeve On Transmission
Old Nov 4, 2016 | 03:25 PM
  #21
djkronik57's Avatar
Originally Posted by abran
I have installed those pans numerous times and wondered why there was 2 drain plugs. Strikes me as odd as the larger plugs port is only sitting approx .75" taller than the drain.
Maybe they use a special connection on their pump?
Did yours come with the white plastic "T" to fit on the inside of the bottom fill port? That raises up the level by a bit more. I am a little worried about having a piece of plastic just wedged on there inside my pan. Doesn't seem to clip on or anything.
Old Nov 4, 2016 | 06:27 PM
  #22
abran's Avatar
I removed that.
Old Nov 7, 2016 | 10:50 AM
  #23
djkronik57's Avatar
I removed that.
Yeah I'm thinking I'll do the same.
Have you had any problems with the supplied paper gasket?
Old Nov 7, 2016 | 02:55 PM
  #24
abran's Avatar
No Problems, but I put a thin coat of right stuff towards the outer edge of the pan and on the outer edge of the trans body.
Old Nov 9, 2016 | 11:26 AM
  #25
Oneruffroad's Avatar
6th Gear
I just went through this entire swap. Whatever you do, don't use the bottom port to check the level on the pan. It will be low. That document is wrong and the depth of the pan should not matter. I found out the hard way and spent 3 saturdays trying to get the level right that way. Fill and check it from the side as normal.
rally1
Feb 22, 2022 06:22 AM
Simonscyclist
Mar 18, 2013 08:11 PM
matt5963
Jan 16, 2012 08:58 AM
MrSabie
Nov 24, 2006 12:59 PM
LRXD
Nov 26, 2005 11:45 AM
