Suspension Diagnosis - Dropping
Old Feb 24, 2022 | 07:58 PM
  #21
Oceanguy33's Avatar
Originally Posted by loanrangie
The filters are felt and i think you'll struggle to clean them out, could try to get some from a craft store ?
here’s an update.
I finally got some felt, got some new beads and put everything together. Runs. But then faults. I’m wondering if the felt is just too much and can’t push air past. I am assuming that the dryer is the air that passes on to the system rather than the other two hoses at the back? Should I try running with only desiccant and no felt filters?
Here’s the error.
Old Feb 24, 2022 | 09:16 PM
  #22
loanrangie's Avatar
As long as the felt was the same thickness/density it should be ok, i wouldn't run without it or you'll being doing it again soon.
This would suggest a leak -
https://www.disco3.co.uk/forum/topic...4875e9f1ce5d4f
Old Feb 25, 2022 | 02:00 PM
  #23
DakotaTravler's Avatar
Yah, that does indeed suggest a leak or poor compressor performance. Did you happen to check the dryer cap for a crack between where the two lines connect?
Old Feb 25, 2022 | 08:16 PM
  #24
Oceanguy33's Avatar
Seems to run without error now.
I unpacked the felt and reused the pieces that were not totally perished. Plugged back in and seems to be ok. Runs like my old lr3…perhaps I have bought myself another year or so…who knows.
Old Feb 25, 2022 | 08:58 PM
  #25
Fingers crossed!
Nuckle
Sep 30, 2024 04:33 PM
skisailbike
Aug 17, 2024 11:35 AM
welder403
LR2
Aug 6, 2021 12:48 PM
JMF20
May 24, 2021 11:26 PM
Mads Jakob Poulsen
Sep 9, 2017 09:00 PM
