Transmission sleeve
Old Jan 30, 2017 | 03:06 PM
  #21
abran's Avatar
Originally Posted by houm_wa
So...you say the fill level is not different. Does that mean that contrary to what was believed on this forum before, the metal pan does NOT reduce the amount of fluid the tranny can hold?
I have never checked the amount of fluid I drain versus fill up with the conversion. But, I do believe its the same amount if not more fluid based on the physical dimensions. The plastic pan has cooling vent fins that are approx 1/8-1/4" and these butt up to the metal cage that holds the heat shield.
The metal pan butts directly up to the cage and has no fins. Just based on this observation I would say it holds as much if not more.
Old Jan 30, 2017 | 04:56 PM
  #22
houm_wa's Avatar
You'd be doing this forum/community a favor if you could make note of that next time you do one of these.
Old Jan 30, 2017 | 07:11 PM
  #23
gfly66's Avatar
Default New Trans service kit
Atlantic British is getting a shipment of a new design as separate filter from the pan so now you can take the old plastic pan down a little, cut the filter tube off and put a new separate filter in with the new pan and eliminate all that other labor stuff. I don't expect to do mine till the parts come in obviously, within the next month. So that is great news!!
Old Jan 30, 2017 | 09:56 PM
  #24
abran's Avatar
OK. I'll try on the next one.
djkronik57
Nov 9, 2016 11:26 AM
Simonscyclist
Mar 18, 2013 08:11 PM
matt5963
Jan 16, 2012 08:58 AM
MrSabie
Nov 24, 2006 12:59 PM
LRXD
Nov 26, 2005 11:45 AM
