What did you do to your LR3 today?
Old Sep 24, 2017 | 07:28 AM
  #411
spannermonkey's Avatar
finally decided to deal with the annoying 'bonnet open' intermittent fault I have. Disconnected the latch, cleaned out the switch which was really gummed up and put it back together - hey presto, no difference!!!
So I just decided I can live without being told my bonnet is open as it should be pretty obvious and no other vehicle I've owned had one, so I simply disconnected the connector, put in a shorting link and now no more warning :-)
Old Sep 24, 2017 | 10:33 AM
  #412
bbyer's Avatar
Default still have my original bonnet
Back in 2005 or thereabouts, Land Rover boasted that the bonnet was the largest sheet of pressed aluminum on any vehicle worldwide. It was a first - never been done before. I suppose the new Ford pickups have the aluminum hood now that Land Rover has proved it out, so large aluminum pressings are no longer unique.
My only real experience with the bonnet catches, or the lack of them was early on when new, one day when I got up to freeway speeds the right front corner of the bonnet stated to vibrate and sort of lift. I watched it for a bit and decided that was not good. I did not recall seeing any bonnet catch messages by the way.
Regardless, I pulled over, stopped, got out and pressed that corner of the bonnet down until I heard the latch click - all good then.
Since then, wherever the bonnet has been opened, upon closing, I pull up on the outside corners to see if there is any movement. On occasion there is and I do the press down thing.
I still have my original bonnet but I suppose now there are lots of bonnets in the junk yards - well maybe not lots as most crashes are frontal but...
Attached Thumbnails What did you do to your LR3 today?-d3-aerial-bracket-wing-right-strip-img_5893.jpg
Old Sep 30, 2017 | 10:43 PM
  #413
Put a new rear wiper blade on both LR3s and washed the 07. Started packing the 06 for MAR.
Old Oct 3, 2017 | 08:44 PM
  #414
Gave it a good wash, wax and detailing inside and out. All packed up for MAR.
Old Oct 9, 2017 | 05:28 PM
  #415
Installed a pair of Terra Firma swivel recovery shackles on my Proud Rhino bumper.
Attached Thumbnails What did you do to your LR3 today?-36933070133_e6ae32295e_z.jpg
Old Oct 20, 2017 | 08:46 AM
  #416
discoverybrazil's Avatar
Default Face lift
Hi my word wide friends! My first time here! I have a disco 3 hse V8 2006 green with 130000km and I loving this car I have for 2 years so I change front disc pads brake, air compressor, and MAF sensor ( by the way o bought from toyota is the same denso sensor!) now I changed transmition fluid by flushing, I put 10 liters of motul mult atf 100% synthetic, I did install wheels , front and side vents grills, and rear led lights, all new silver letters all from lr4, now is very cool!
I did install ends muffler exhaust and take off resonator! Is great sound!
next I want change diffs and gear box oils change !
Old Oct 20, 2017 | 08:54 AM
  #417
Default first access
hi guys!
Old Oct 21, 2017 | 08:41 PM
  #418
Today I changed gear box oil and steering fluid ! Very easy!
Old Oct 22, 2017 | 04:20 PM
  #419
Captain Sygo's Avatar
Default Seat Rock
Fixed the seat knock issue - that little slippage in the driver's seat when starting up from a stop. Super simple fix, following these instructions:
http://www.rrsport.co.uk/gallery/alb...1/seatrock.pdf
-Captain Sygo
'05 LR3 SE
Old Oct 22, 2017 | 10:53 PM
  #420
Talking
That has got to be the cleanest and shiniest diff Ive ever seen!
