Misfire in #7 only.
Old Aug 30, 2023 | 02:04 PM
abran's Avatar
Sorry, original post!
Old Apr 28, 2026 | 11:02 PM
Lr4BothellWA's Avatar
Default Similar issue
Originally Posted by newdude
2010 lr4, 158k miles. Gap IID tool shows a misfire for cylinder #7, no other engine/petrol codes. Symptoms are reduced performance. I swapped coil from 7 to 5, cleared code, and no difference. Still misfire. Changed spark plug with new one, no difference. I inspected the harness for any cracks, no damage. The spark plug from 5 and 7 do not smell like fuel.
If I was to get a voltmeter to the injector or coil harness, what should I be reading? Voltage or resistance? And how much?
Other then that, any advice on what to do next?
PCM-Engine Petrol
  • P0307-00 (AF) Cylinder 7 misfire detected
  • P0316-00 (AF) Misfire detected on start-up (first 1000 revolutions)
UPDATE SOLVED: BAD CONNECTOR. Wiring was ok but the pins or wiring iside the connector itself wasn’t. Also got the wrong type of connector, but it did work for a month. You have to get this one
Man I had high hopes when I found this thread. My 2011 lr4 gives me the same codes but without any noticeable misfire. Live values through my GAP tool show no misfires while under load or driving of any kind. Only counts “misfires” when parked or stopped. Again, no noticeable symptoms. Just a check engine light that turns itself off for a while and then comes back. I have done plugs, coils, #7 injector, and just did #7 new connector for the coil. I am at a loss. What am I missing? Thanks
Old Apr 29, 2026 | 12:12 PM
abran's Avatar
Compression test, if that’s good, leak down test.
mooni
LR4
Jan 20, 2023 05:46 AM
sdtimb
Jun 11, 2021 10:34 PM
TheSloth
Aug 1, 2017 11:57 AM
PNuckett
Feb 17, 2017 05:05 PM
RealRitzcracker
Jul 12, 2010 10:57 PM
