1 year Service
Old Nov 23, 2024 | 11:18 AM
  #111
GavinC's Avatar
Originally Posted by Defendit..
@GavinC
Nice job, how did the oil look ?
Not being very knowledgable on these things, it looked jet black and shiny with a normal looking consistency and viscosity.
I suspect my assessment may be about as accurate as a stormtrooper with a blaster.
Old Nov 23, 2024 | 06:50 PM
  #112
CincyRovers's Avatar
Yellowstone is some good stuff; I actually had a glass last night! But my go-to is Weller or New Riff, which is a local distillery right across the river in northern KY. New Riff was started by the same guy who owns The Party Source, one of, if not the biggest liquor store in the country.
Old Dec 20, 2024 | 05:10 PM
  #113
GavinC's Avatar
Default Wiper Rubber replacement
Another quick service item
$6 for 4 rubber replacements.
The rear wiper could not be replaced. It gets almost no use anyway so not really a bother.
A few minutes to remove old and replace with new
Rear wiper rubber serves as it’s own washer jet.
Activate service mode to remove blade.
Washer nozzle attaches to base of blade.
Multiple washer jets/pores in blade. Clever.
Old Dec 22, 2024 | 10:39 AM
  #114
GavinC's Avatar
Default P400 Spark Plug Change 53,300 miles
This was a fiendishly difficult job. Broad steps are below. Electrical connectors, clamps, clips, hoses, and factory torque values have been omitted.
A little earlier than the scheduled maintenance. Use profile may justify doing it earlier than the prescribed 63,000 miles. Seeing the plugs and feeling how they came out, I think this sort of time-frame is reasonable.
Parts needed
6 Spark plugs. I used OEM from Landleaping.com ​​​​​​​
Special tools neededSteps
  • Verify spark plugs are correctly gapped. 0.6-0.65mm. The OEM plugs LR178881 should be correct from factory and should not be adjusted.
  • Disconnect battery
  • Support hood and remove struts
  • Remove Wiper arms and place to side.
  • Remove front cowl
  • Remove Air duct
  • Remove Engine Cross-member
  • Remove Front secondary bulkhead
  • Put the Charge air cooler into service position. (This was a nightmarishly difficult step due to the short hoses)
  • Remove ignition coils
  • Remove spark plugs
  • Replace spark plugs with new.
  • Reposition charge air cooler. Again insanely difficult.
  • Replace all the removed stuff in reverse order.
  • Beverage(s)
Looking into the spark plug housing and the cylinder below.
This hose was a nightmare to remove and reattach
All back together again
Cheers. A disturbingly small measure.
One minor snafu.
A cross-threaded bolt in the engine crossmember.
This is likely from before courtesy of my dealership. I will need to re-tap that thread and torque it down. M10 55Nm on the bolt.
Everything else torqued to spec. A few unused clips in the engine bay and some missing bolts I replaced now in use again. (Another of my dealer’s signatures.)
Merry Christmas
Merry Christmas
Old Dec 22, 2024 | 10:28 PM
  #115
GavinC's Avatar
GAP tool to read for any misfires today. It would appear all is in order.
Old Dec 30, 2024 | 11:39 AM
  #116
GrouseK9's Avatar
Well done! Hopefully before I get to 60k someone will post a more in-depth video of that short cooler hose with some tips and tricks!
Old Dec 30, 2024 | 04:01 PM
  #117
GavinC's Avatar
Yeah I'd love to know how better to remove and reattach it. Some sort of hose removal tool if one exists would be the right job. There are two others that were tricky too but this one was a real bear.
Old Jan 10, 2025 | 10:28 PM
  #118
GavinC's Avatar
Default 54,400 oil and filter change
Routine little task for a Friday evening.
30 minutes to completing tidy up and having oil ready for disposal.
simple as you’d like.
Recut the thread for the M10 bolt cross threaded at an earlier time. Engine cross member. Recut an M10 bolt I had from the AC armor to match. All good again.
Old Jan 22, 2025 | 08:51 PM
  #119
GavinC's Avatar
Next items to address are
Transmission
Front Diff
Both supposedly lifetime fills but that doesn't seem to make much sense to me.
Edit: Both actually listed as service items at the 105,000me service. Similarly transfer case and rear diff are listed at that mileage too. Seems very long.
ZF have 80,000km service interval on their own spec sheet so perhaps this is worth following. I'm there or there abouts at 55,000 miles.
Edit: ZF now recommend a 150k km service interval. Shorter if arduous driving conditions are met.
Pan, filter , new bolts and plugs. Service manual also shows a special tool needed to get access to the drain plug but a poster in Defender2.net stated it not being needed.
Front diff appears to be the same as the rear in terms of hardware. New drain and fill plugs needed. Different oil to the rear as that was the eDiff.
Front Differential
  • Differential Oil x2 LR050750
  • Plug TYB500060
  • Plug TYB500110
Land Rover Part number
Wondering if anyone has done these items yet and could share any pointers.
Old Jan 24, 2025 | 06:18 PM
  #120
GavinC's Avatar
Transmission drain and fill.
The final step on the 3L Petrol and Diesel engines is after going through all the steps to get a precise and correct fill level, the instructions are to remove 350ml of fluid and call it done.
Seems very strange. Only on the 3L. Not the V8 or the 2L engines.
I'd love to know the why.
Edit: Possible theory is that it is due to a slightly angled transmission on the Defender. Ie: when the Defender sits level the transmission is tilted meaning a slight overfill after the steps have been taken. Perhaps. someone like @sarek might know more.
This kit seems to be the best price on the transmission pan and fluids. Everything you need from FCP Euro for $250
