GAP IID Tool Summary
Old Dec 14, 2024 | 01:56 PM
  #381
Dapirate's Avatar
Originally Posted by vinceleo
I asked this before, and we didn't have a solution... I did the "Remember Stop/start setting" (MultiCAN-566 MHLastUserMode = Enabled) approx a year ago and it had no impact on my started/stop as I have to push the button every time I start the vehicle (first world problems, I know).
Last week, I undid the programming change and left it like that for a day or two, reset PIVI a few times and over the weekend, I re-did the program change, reset PIVI a few times hoping it would take. It didn't.
I have a 2021 110 P400 and from what I can tell, the programming change doesn't work on the earlier P400's. I thought I would check to see if anyone found a workaround.
2021 P400 and mine doesn't work either. That was the main reason I bought the tool too 😂
Old Dec 14, 2024 | 02:34 PM
  #382
Jim 90's Avatar
On the earlier models you could make the change without the IID tool.
Old Dec 15, 2024 | 08:43 AM
  #383
vinceleo's Avatar
A permanent change to lock out the start/stop? I am not aware and haven't found anything via mult searches. Please share.
Old Dec 15, 2024 | 10:49 AM
  #384
Jim 90's Avatar
YouTube - Defender L663 - Configurable Start/Start Activation; it’s for a 2020 I think. LR retrofits. Hope I’m not sending you on a bad chase.
Old Dec 16, 2024 | 02:35 AM
  #385
ColinD's Avatar
Originally Posted by Phil McCracken
Thanks - I've tried that and all other combinations which I can think of. Still no dice.
The start button does not want to be pressed.
Did you get sorted? I have the same problem
Old Dec 16, 2024 | 02:42 AM
  #386
ColinD's Avatar
I thought I was replying to a post on here. This is the info Defender Pivi Pro MY25 Interface
* MultiCAN-882 Sidebar Controls
from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i"
* MultiCAN-892 SideBar Climate
from "Climate Icon on Side Bar Not Available" to "Climate Icon on SIde Bar Available - FICP Replacement"
* MultiCAN-896 ReCircle Soft Button
from "Not Fitted" to "Soft Button Fitted with timed and latched logic"
* MultiCAN-897 Max AC Soft Button
from "Not Fitted" to "Soft Button Fitted"
* MultiCAN-897 Max Defrost Soft Button
* MultiCAN-897 AC OnOff Soft Button
* MultiCAN-897
Auto Climate Soft Button
from "Front
AUTO Climate Soft Button Not Fitted" to "Front AUTO Climate Soft Button Fitted"
* MultiCAN-898 Front Htd Screen Soft Button
* MultiCAN-898 Rear Htd Screen Soft Button
* MultiCAN-894 Volume Soft Keys
from "Not Fitted" to "Audio Volume Soft Keys pattern 1" Changed back to Not Fitted and it worked
Old Dec 16, 2024 | 08:14 AM
  #387
ColinD's Avatar
Originally Posted by markjlr
How do you get the corner Speed assist?
Old Dec 16, 2024 | 10:16 AM
  #388
vinceleo's Avatar
I tried this method for my 2021 P400... no joy
From what I can find, the workarounds (including the GAP tool) haven't worked on the early year P400. I would love for someone to prove me wrong and find a solution!
Old Dec 16, 2024 | 10:41 AM
  #389
Phil McCracken's Avatar
Unfortunately, No. I've been meaning to back out the changes, restart the vehicle multiple times and then modify the settings again to see if that helps, I just haven't gotten around to it.
Old Dec 18, 2024 | 02:24 PM
  #390
Lantisbred's Avatar
Default Nothing Showing Under Service / Test
Just got my GAP tool and was looking to progam a new key. But despite updating the software and putting my rig into service mode via the LR app... I don't see any of the standard options under the main menu Service / Test.
Does anyone have experience with this issue and a solution? Here a screen shot of what I'm seeing.
