GAP IID Tool Summary
Old Dec 5, 2025 | 03:49 PM
  #581
stevemfr's Avatar
[quote=magaland;940454]
Originally Posted by Mattweigham
Привет, извините, если такой вопрос уже задавался, но есть ли способ отключить систему помощи водителю, кроме как нажимать кнопку каждый раз при запуске автомобиля с помощью инструмента GAP 4G?[/QUOTE
Old Dec 12, 2025 | 11:20 AM
  #582
magaland's Avatar
Do you have a wiring diagram?
Thanks.
Old Jan 8, 2026 | 06:58 AM
  #583
TheInfamousDrew's Avatar
Hey guys,
Just changed a few things on our MY26 130 and now I can't turn on lane assist or ACC now.
Changes:
- Remember Stop/start setting
- Change Splash Screen to "Defender 007"
- Activate WIFI/WLAN Hotspot
- Disable Seatbelt Reminder front and rear
- Activate Dynamic mode using these settings:
  • EUCD-129 Terrain Response Fitment
    Change to: Auto Terrain Response Dynamic & Configurable Dynamic Mode
  • EUCD-245 Dynamic-I
    Change to: Dynamic-i Content with Configurable Dynamic Mode Screen
  • MultiCAN-562 DynamicProgMode
    Change to: Available for selection without timeout (Other possible value: Available for selection with timeout)
  • MultiCAN-605 ConfigDynamicMode
    Changed to: Fitted
  • MultiCAN-777 Ter Dyn Select In FCPB
    Changed to: Rotary used for selection within touch screen
Any ideas?
Old Jan 8, 2026 | 08:01 AM
  #584
GavinC's Avatar
Seatbelt needs to be on to activate cruise control. LKA too possibly.
just a thought as you may have been enjoying your absent seatbelt chime.
Old Jan 8, 2026 | 08:41 AM
  #585
I will check on that!
New issue.......I've made all the changes for Dynamic mode, but I don't have the option on the home screen or anywhere.
Old Jan 8, 2026 | 09:25 AM
  #586
H1Tad's Avatar
Not abnormal. It took like, a week for my dynamic mode icon to show up.
Try hard cycling the pivi screen by pressing and holding the ****/button down to turn off then turn it back on.
  #587
nashvegas's Avatar
@TheInfamousDrew You’ve missed something or yes, as above you need to cycle the thing and wait a beat. Unless perhaps you have a 2025 or 2026 vehicle ? (which may not work with this yet)
Here’s a recap of everything I did with comments, I’d go through and check each step against this below. When I do this I take detailed notes which Ive pasted below
Dynamic Mode
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
Standard: Not available for selection
Changed to: Available for selection without timeout
Standard: Not Fitted
Changed to: Fitted
(this added icons in the instrument cluster to mirror those in the pivi system - cool)
Was: Auto Terrain Response
Changed to: Auto terrain response dynamic and configurable dynamic mode
Works properly w/ 245/562/605 above. Changes interior lights to red, New configurable Dynamic screen, icon, and appears in instrument cluster, BUT Gauges do *not* turn red as have seen in some in the forums.
So then I changed 129 which added icons to instrument cluster when selecting modes — but the gauges still don’t go red like in a RRSport.
THEN To get Dynamic mode to be selectable with rotary dial too:
MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout” (NO idea what this actually does or does not do)
MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen”
(Note tried 778 didn’t make auto selectable via rotary - false hope!)
THEN -- It was all working except that the dynamic mode icon was not appearing on the drivers display when adjusting the rotary **** to select a mode. I found that adding this did the trick. I had to change this and change it BACK after doing 777, for whatever reason.
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
Old Jan 8, 2026 | 09:38 AM
  #588
Thanks, i I will give this all a try.
It is a brand new 2026 X-Dynamic SE 130.
Dynamic Mode
EUCD-245 Dynamic-I
Changed to: Fitted
Old Jan 8, 2026 | 10:10 AM
  #589
Simple reset got it working!!
Old Jan 9, 2026 | 11:39 AM
  #590
DGINAZ's Avatar
I have my front seatbelt reminder chime disabled and my LKA and active cruise seems to be working fine for me - I have a 2025 110 P400.
