Air Conditioning Fail
Old Jun 9, 2014 | 06:13 PM
Aus-trek's Avatar
Default Air Conditioning Fail
Jumped in the Disco yesterday, no air conditioning. It was working fine the day before but now nothing. The fan still works. I've checked a couple of fuses but measured OK. Any ideas?
Old Jun 9, 2014 | 06:39 PM
abran's Avatar
It could be the switch in the dash. With the car running, push the switch on.
Open the hood and look at the AC compressor to see if the center is spinning or just the outer pulley. If the center isn't spinning, the switch has not turned on the compressor.
I have fixed more than 3 AC systems by changing the switch out.
Good luck, interested to hear if this is the fix.
Old Jun 10, 2014 | 06:01 PM
Aus-trek's Avatar
Thanks Abran, I'll check it on the weekend and get back to you.
Old Jun 29, 2014 | 05:53 PM
Aus-trek's Avatar
Finally had a chance to look at the compressor. The centre plate/clutch was missing. Luckily I found it nesting amongst some pipes lower in the bay. Very lucky. All good now, thanks.
Old Jun 30, 2014 | 08:33 AM
TOM R's Avatar
Say what???
Old Jul 1, 2014 | 05:37 PM
Aus-trek's Avatar
That's right! The bus was driven for 2 weeks and the plate didn't dislodge from its nest.
graveshaker
Nov 16, 2014 02:41 PM
zski128
May 30, 2013 06:38 PM
reddiscovery2
Dec 18, 2012 08:54 PM
mpompliano
Freelander
Jul 31, 2012 06:13 PM
