Replacing Camshaft
Old Apr 12, 2012 | 11:54 AM
  #51
ColoDisco's Avatar
I don't think bump start works on this engine as it spins counter clock. I am removing the oil pan now.
Old Apr 12, 2012 | 12:06 PM
  #52
Jake1996D1's Avatar
Originally Posted by ColoDisco
Yes. Have the D&D kit. Came with cam, timing gears, chain, tappets, lube for cam and break in oil additive from crane cams. It is a crower cam and tappets.
Damn thats a good deal.. Looks like I better start making a tube chassis for this rusted out 95 I have out back
Old Apr 12, 2012 | 12:09 PM
  #53
ColoDisco's Avatar
It was only $370 shipped.
Old Apr 12, 2012 | 12:18 PM
  #54
slanginsanjuan's Avatar
show it...
Old Apr 12, 2012 | 01:28 PM
  #55
ColoDisco's Avatar
Originally Posted by slanginsanjuan
show it...
Well normally I would just tell you to call, but since you asked:
Old Apr 12, 2012 | 01:32 PM
  #56
noooo bro, sorry.
i meant show the parts you got.
Old Apr 12, 2012 | 01:51 PM
  #57
ColoDisco's Avatar
Midday progress:
Labeled the plug wires to make reinstallation easier
Cap rotor and wires removed:
Drained the oil, while that was dripping I removed as much as possible from the intake:
Removed oil pan:
Lower end is about how I expected for 190k miles. No metal particulates seen.
For this afternoon,
Loosen crank bolt
Drain coolant
Remove radiator
Continue disassembly of front end.
If I get ambitious possibly remove intake.
Old Apr 12, 2012 | 01:54 PM
  #58
ColoDisco's Avatar
noooo bro, sorry.
Posted that in the other thread. But here you go!
Old Apr 12, 2012 | 02:00 PM
  #59
nice work..moving along. can't wait to hear it tickless.
Old Apr 12, 2012 | 08:10 PM
  #60
ColoDisco's Avatar
Lots of progress this afternoon. There is a surprise at the end!
Used wood to lock up the crank and remove the crank pulley bolt, worked like a charm!
Pulley off:
Moved on to the distributor and radiator.
Removed cover with oil pump:
Made a bolt diagram to make sure I put the 3longer bolt back in the right spot I highly recommend this:Name:  1875781e.jpg
Follow these next 3 images as they zoom in on the second cylinder on the left bank.
Blue circle is where this lifter lived:
Hello mr. Ticky Ticky!
Tomorrow morning the cam comes out.
