So what did you do to your Disco today?
Old May 30, 2017 | 06:16 AM
  #4021
WaltNYC's Avatar
Installed new driver's side swivel ball, pins, seals. Man, 20 years of grease and grim sure builds up. Passenger side isn't leaking but I'll get to it over the coming months.
Thanks to Paul and Trevor for parts. Everything was perfect.
Old May 30, 2017 | 03:04 PM
  #4022
hrhoward's Avatar
Shocks and Springs. All four corners. Sitting where it's supposed to be again.
Old Jun 13, 2017 | 08:17 PM
  #4023
aemnky606's Avatar
Added a 120v plug to keep my battery's charged when it's parked for extended time.
Old Jun 13, 2017 | 08:47 PM
  #4024
JUKE179r's Avatar
Nice! How did you wire it up?
Old Jun 13, 2017 | 09:00 PM
  #4025
stillruns's Avatar
On my to do list. What did you go with?
Old Jun 13, 2017 | 09:01 PM
  #4026
stillruns's Avatar
Do tell?
  #4027
aemnky606's Avatar
The plug has a pig tail about a foot in length with a female end on it, Then my charger plugs in to that.
Plug:
Amazon Amazon
Charger:
Amazon Amazon
Old Jun 14, 2017 | 06:56 AM
  #4028
WaltNYC's Avatar
That is a nice and clean installation.
Old Jun 15, 2017 | 12:44 PM
  #4029
AbnMike's Avatar
Not today, but a couple weekends ago:
New calipers and pads at all four corners.
New ABS sensors in the fronts.
New Master Cylinder and brake booster.
New slotted front rotors (had replaced the rears last summer).
I actually have good brakes for a 20 year old lifted British truck with big tires...
Old Jun 19, 2017 | 08:06 PM
  #4030
ROB99DISCOSD's Avatar
Over last few days and officially stamped TESTED & INSPECTED today:
*All 4 u joints replaced
*Drain & replaced oil in both Diff's
*Drain & replaced T Case fluid w/leak sealer
*Removed T Case inspection plate, resealed rtv gasket, and put in new bolts
*Replaced rear sway bar end links
and diagnosed:
*Need new front sway bar end links
*Warped rear right brake rotor
*Leaking oil cooler hose(s)
The list is long my son.....
