What Hose Is It
Old Mar 18, 2013 | 09:12 AM
dsmeddy's Avatar
Default What Hose Is It
I have a '97 Disco and the hose coming out of the oil pan next to the oil filter up to the radiator is leaking, What is that hose name and part # if anyone knows? TY
Old Mar 18, 2013 | 09:22 AM
keoni004's Avatar
Oil cooler line.
It is an oil cooler line, and if leaking it should be oil, not coolant. See Land Rover Parts, Accessories and Information and select the exact one. I got mine from the boneyard. IMHO doing both at same time may save future problems.
Old Mar 18, 2013 | 09:27 AM
keoni004's Avatar
Here's the thread with a ton of info about it. https://landroverforums.com/forum/di...er-line-45815/
Old Mar 18, 2013 | 09:44 AM
dsmeddy's Avatar
So both these lines are Oil Lines and should be done together I suppose?
I tried to upload a picture from the Leaky oil forum but didn't quite know how
Old Mar 18, 2013 | 09:57 AM
keoni004's Avatar
If one's leaking, the other is on its last legs. Save yourself the trouble of doing the job twice and replace them both. Prices vary depending on what lines you want. Rebuilding them is less than $50-100, vendors here sell them for under $200, Trailhead's are about $300, and OEM is higher than that.
Old Mar 18, 2013 | 10:09 AM
dsmeddy's Avatar
Savannah Buzz sent a good link where to find them as well as Rovahfarm has them I believe. It will be done one of these days. Thanks for advice
Old Mar 18, 2013 | 11:21 AM
Number 5 hoses on battery side. On the driver side those are for tranny cooler (red fluid). So you have three radiators in one. In an emergency you could bypass the hoses (attach end to end), a D2 may or may not have an oil cooler based on VIN. See attached. Some leaks are just o-rings.
File Type: pdf
Old Mar 18, 2013 | 04:58 PM
dsmeddy's Avatar
You are correct sir #5 are the 2 I shall replace one day
Old Mar 18, 2013 | 10:39 PM
keoni004's Avatar
Sooner rather than later? Trailhead 4X4 & Offroad
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
Doss
Mar 26, 2006 06:00 PM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
