7mm vs. 8mm spark plug wires
Old Sep 14, 2012 | 08:27 AM
FLDiscoII's Avatar
Originally Posted by Rover De Land
I just want to remind people these are land rovers, you can buy the best most expensive everything but it won't change a thing.
True, these trucks are always going to have issues. But there are definitely things that you can do to change things for the better. There aren't any magic fixes, but when you use quality parts you're bettering your odds. Quality doesn't always mean most expensive. A quality 8mm silicone wire is going to make a difference, and will usually last much longer.
Old Sep 14, 2012 | 08:33 AM
Antmen's Avatar
I see your point, but I still wouldn't put, as an example, Chinese-made U-joints in my propshaft.
Old Sep 14, 2012 | 11:11 AM
Joshman's Avatar
i am going to try the Kingsborne ones in 8mm. Thanks, everyone, for weighing in.
Old Sep 14, 2012 | 12:59 PM
0304Disco's Avatar
You won't be disappointed, besides they are just wires and you probably wouldn't notice a differenct if you installed the cheapest vs. the most expensive wires. I always try to buy the best at the lowest price. Does the best really make a difference, most likely not, but piece of mind does weigh in on it a lot.
Old Nov 13, 2012 | 10:52 PM
Climbs's Avatar
7th Gear
Default Magnecor 7mm vs Magnecor 8mm?
Much difference between the two?
Old Nov 14, 2012 | 12:42 AM
From the standpoint of holding it in your hand, nope, both will get your attention. The thicker insulation will last longer in the hot engine compartment. The silicone based cables last longer before cracking.
Old Nov 14, 2012 | 09:10 AM
mirrajumper's Avatar
The OEM wires have a centering ring inside the plug end I think. This prevents the wire attaching to the ignition coil incorrectly and breaking. Magnecors do not have these.
Old Nov 14, 2012 | 09:24 AM
clanch's Avatar
I used Eurospare wires that use factory ends and Denso spark plugs.
iownme
May 21, 2017 11:36 AM
cosmiccharlie
May 13, 2015 10:45 AM
Disco Den
Mar 28, 2010 12:42 PM
03discoman
Feb 26, 2010 04:47 PM
cegibbs3
Jun 12, 2009 08:16 PM
