Flashing M and S lights '01 Discovery
Old May 1, 2015 | 07:45 PM
  #41
abran's Avatar
The voltage reading sounds right, but I'm still betting on battery.
Let's see what others think.
Old May 1, 2015 | 08:27 PM
  #42
ssigirl's Avatar
Also the date on battery is 6/14.
Old May 1, 2015 | 08:34 PM
  #43
abran's Avatar
Oh, like I said... It's probably not the battery.
Jk, I have only ever seen this problem with a voltage issue. Did the car sit for any long amount of time without running?
Can you turn the battery in under manufacturers warranty for a new one? What brand is it?
It could also be your charging system, but I feel like you would have problems starting the car after repeatedly driving.
My last guess is a faulty electrical connector which is not giving enough voltage to the trans electricals.
I highly doubt you need a new trans though.
Old May 1, 2015 | 08:47 PM
  #44
ssigirl's Avatar
hmmm, I stopped by a transmission shop and they were knowledgable about the xyz switch and said they would test everything. I haven't made an appt. yet but this problem is happening at least daily. I'll ask them if they also handle items out of scope of transmissions. I will have to look at battery in the morning. Like I said, I've only had my Disco for about a month. I've been under the hood probably 100 times in the last 30 days :-/
Old May 1, 2015 | 09:03 PM
  #45
abran's Avatar
I don't think it's the XYZ switch. There are other electrical connections on the trans.
As I understand it the XYZ switch tell the the computer what gear you have physically shifted into(PRD321). As far as the function of the transmission, that is controlled by a transmission ECU.
Someone on here has to have an alternate suggestion.
Old May 1, 2015 | 10:14 PM
  #46
ssigirl's Avatar
ok, thank you. Somebody's got the answer :-)
Old May 2, 2015 | 09:00 AM
  #47
abran's Avatar
Check this post. This guys problem was the connector at the trans.
https://landroverforums.com/forum/di...linking-56123/
Old May 3, 2015 | 11:16 AM
  #48
jlsalazar101's Avatar
[QUOTE=nynole;154315]+1 Battery[/QUOTE
my disco has two mode buttons the M stands for manual and the S stands for sport.there is a mode button on the column and the other behind the shifter.good luck and if you don't have one get a owners manual.
Old May 3, 2015 | 03:19 PM
  #49
ssigirl's Avatar
Yes, I have a mode button too. But it's more than just m & s lights flashing, it doesn't accelerate and I have to move it to p or n and turn off and restart while people are behind me. I'm going to go check the battery and probably replace it. I do believe it sat for a long time. It was a 3rd car for a retired couple.
Old May 3, 2015 | 06:34 PM
  #50
shanechevelle's Avatar
what is the battery voltage while CRANKING???
