Front Driveshaft Check
Old Jun 2, 2013 | 08:50 AM
nvrenuf's Avatar
Default Front Driveshaft Check
So I just climbed under my new to me '03 DiscoII. Front drive shaft has grease zerks on front end going into diff. I got all excited. Then I moved around to check back end of shaft. Looks like other end, going into tranny does not have any grease points.
Is this the common problem. So I just need to rebuild that end going into the tranny?
Am I right here?
Old Jun 2, 2013 | 10:19 AM
antichrist's Avatar
No, you should rebuild it completely.
https://landroverforums.com/forum/ge...02/#post164811
Old Jun 2, 2013 | 11:39 AM
Either end makes a formidable weapon thrashing about at hundreds of rpm. If you have the spud shown on the transfer case, or installed CDL, you can engage CDL and drive on the back shaft while you rework the front.
Attached Thumbnails Front Driveshaft Check-xznw5.jpg   Front Driveshaft Check-zjtah.jpg
robert.juric
Nov 3, 2022 06:08 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
clandrovers
Oct 10, 2010 01:09 PM
tads
Aug 2, 2007 12:09 PM
jusspasd
Oct 2, 2006 01:15 PM
