Head gaskets, now lifters and cams?
Old Dec 13, 2018 | 04:23 PM
  #31
The Deputy's Avatar
Agree^^^
Easy way to check, start engine, but don't turn on heater. If you don't smell anti-freeze in the cabin after about ten minutes, turn heater motor on...if you smell it then...then it is most likely the heater core.
​​​​​​​ Brian.
Old Dec 13, 2018 | 06:33 PM
  #32
Llamasayswhat's Avatar
Agree^^^
Brian.
The heaters in our car have constant flow through the core weather the heater is on or off. This shouldn't make a difference unless you're hinting at smelling it on the air stream as it pumps air past the leaking core
Old Dec 13, 2018 | 08:16 PM
  #33
Extinct's Avatar
Might consider using a system pressure tester and listen for leaks
Old Dec 14, 2018 | 02:36 AM
  #34
The Deputy's Avatar
Yes, the heater fan blows the smell to your nostrils. If he runs the rover for ten minutes and doesn't seem to smell anything, inside or out, and then turns on the blower motor and smells anti-freeze...most likely...heater core is leaking.
​​​​​​​ Brian.
Old Dec 14, 2018 | 06:36 AM
  #35
Roby466's Avatar
Thanks for the advices. The weird thing is that the smell goes away. And not because we get used to it. If my wife drives the car, she will get the smell, after 10 minutes I get in with her, there is no more smell.
It could be that the heater core has cooland just seeping through and it accumulates a bit after shutdown and the smell comes shortly after startup and stops as it evaporates...
I will do the pressure test again and try to look. I fear though, when I did the head gaskets it was because it was leaking at the back of the heads around the bellhousing and on the cats and making the smell.
The expansion tank leaks too but according to the LR dealer, that's a problem worldwide with all the new ones they sell. They won't give the money back though. I have picked up an old one from a truck being parted so I will try that one next.
Old Dec 14, 2018 | 08:09 AM
  #36
The Deputy's Avatar
Yes, if it is the heater core...it is most likely seeping...and it burns off after getting warm and with air blowing across heater core. If this is an issue with you and your wife...I would sell it to the guy who does research as a biologist on skunks...watched an interesting PBS show about him...he has no sense of smell at all. So, this would be the perfect vehicle for him...lol.
Brian.
Old Dec 14, 2018 | 12:25 PM
  #37
Roby466's Avatar
Lol!!
not an issue with my wife and I. She is very understanding of my problem with LRs and is even encouraging me to go back to a Defender . I hope it’s the HC really. Pulling the dash is not too bad compared to another HG job. I just finished doing that on our Eurovan T4... definitely a few evenings well spent
I’ll do some more testings!
Old Dec 14, 2018 | 01:33 PM
  #38
Richard Gallant's Avatar
Check your throttle body heater hoses, drivers side. If they leak you can get a bit of pooling when you shut down ,next time you start up it dribbles on the exhaust and you smell anti-freeze for a few minutes just as the engine heats up. You can usually see a bit of anti-freeze on the valve cover.
Old Dec 15, 2018 | 10:39 AM
  #39
Roby466's Avatar
Good call with the TB hoses. I replaced them a couple years ago but who knows
I'll keep you posted!
Cheers
David
ImQuattro
Jan 19, 2024 02:54 PM
Squid4life
Dec 23, 2016 06:03 PM
clint70
Dec 9, 2014 04:20 PM
RicketyTick
Jul 8, 2014 07:21 PM
BCDisco2Lando
Aug 7, 2013 10:19 AM
