High Idle Temps....2004 Disco....Thoughts?
Old Oct 18, 2017 | 08:08 AM
  #31
dtmbinb's Avatar
I always bleed it on a steep hill. Idle Temps have gradually gotten worse the last few months. I think the thermostat might be on the way out.
Old Oct 19, 2017 | 07:57 AM
  #32
shanechevelle's Avatar
green coolant?
Old Oct 19, 2017 | 08:32 AM
  #33
dtmbinb's Avatar
Pentosin sf. It's the same as vw/Audi g12. 50/50 with distilled water.
Old Oct 20, 2017 | 05:01 AM
  #34
well, if you or anyone else for that matter find yourself in my neck of the woods, feel free to stop by and we can go over your rover.
I would start by changing your stat. Park it on a steep hill, running, heat on all the way, and open the bleed hole on the plastic T.
My fiat had this same problem, the tech line told me the front must be elevated if I didn't have the proper tools.
Old Oct 23, 2017 | 05:40 PM
  #35
dtmbinb's Avatar
Update...replaced the oem 180 thermostat with a warranty part from Lucky8. Did a quick bleed by raising the reservoir and taking out the bleed screw. Let coolant flow freely out the bleed hole for a few seconds. Topped it off and idled with the heat on. On to the test drive.....temps have dropped 6-10 degrees across the board! Lower radiator hose below thermostat is now getting warm. Apparently the oem 180 stat was not opening all the way. I'll check the bleeding over the next week and report back. Looks like the oem 180 failed in less than 6 months. A big thanks to Lucky8 for their custom service!
Old Oct 24, 2017 | 04:37 AM
  #36
Next time you bleed, park upwards on a steep hill. Heat on high.
wick_60010
Nov 22, 2017 04:25 AM
Jmcbghs2012
Nov 7, 2016 04:08 AM
coors
Dec 17, 2014 09:05 AM
johnnyjohnny
Feb 23, 2014 08:55 AM
zombiedisco
Jul 18, 2013 05:20 PM
