Is my WATER PUMP bad?
Old 06-06-2014, 07:51 AM
RicketyTick's Avatar
Originally Posted by masterseung
It's either the block or the head... not sure if there is any way to tell..
Yep, looking for an engine..
You'll probably have to tear it down and carry to a machine shop to check pressure test everything.
  #62
Old 06-06-2014, 11:42 AM
masterseung's Avatar
Lot more than I bargained for...
  #63
Old 06-06-2014, 04:04 PM
How do you know for sure it's not a head gasket?
  #64
Old 06-06-2014, 05:39 PM
Not sure but head gasket was already done
  #65
Old 06-07-2014, 09:24 AM
The head gasket was changed 1k miles ago..
I'm guessing, block cracked behind cylinder sleeve, cracked head, head wasn't properly skimmed and head gasket gave out again due to head being warped. Just thoughts and just trying to help but, have you removed the plugs in 3 & 5 to see if you have water in those cylinders or steam cleaned pistons? I had a misfire on #7 and when I removed the plug and turned the engine over it sprayed water everywhere but, I suspect mine was more sudden than yours. Mine was all at once with no small leaks.
DiscoTanB
08-13-2015 08:10 AM
dswilly
10-15-2012 12:28 AM
zracin
11-03-2011 12:17 PM
Savannah Buzz
07-21-2011 08:02 PM
imnothans
11-30-2009 07:53 PM
Quick Reply: Is my WATER PUMP bad?
