P0455 Purge Valve Question
Old Oct 4, 2014 | 08:58 AM
thesoundguru's Avatar
from what I've seen, nobody really talks well of the dorman part auto zone carries.
Old Oct 4, 2014 | 01:30 PM
04duxlr's Avatar
Although it does come with a lifetime warranty! I fixed mine by blowing injector cleaner through it while activating the solenoid. I have a pump sprayer set up with a pressure gauge that I filled with injector cleaner. I used to to check my injectors while I was replacing my head gaskets. I hooked the hose up to the inlet on the purge valve and pumped the tank up to 15 psi. I used leads off the battery to trigger the valve, which sent the cleaner through it. I did it a couple of times. Now that the car is back together I haven't seen the code come back. It's only been a couple of tanks so far though. Is it worth the effort given the price? Hard to say but it did work.
Old Oct 4, 2014 | 03:59 PM
KernowDiscovery's Avatar
Did any of you guys have it go out without clearing codes? I've been dealing with this the past 2 months. Replaced the gas cap, reset the codes and it was out for close to a month. Then it came back on after a week and stayed on for a little over a week and it went off today? I don't get it. Any idea why it would come on and then go out without messing with anything? I'm not complaining - just curious. I'd rather have my 3 amigo lights disappear!
Old Oct 4, 2014 | 04:19 PM
04duxlr's Avatar
The code comes from the testing of the system by the computer. It adds pressure using a pump then looks for a drop in pressure. Depending on the volume of air in the system, there may be low enough levels of pressure loss to not trigger a code. I found I was getting codes when the tank was mostly empty.
Old Oct 4, 2014 | 05:48 PM
Interesting.. I was getting low on gas the last time it came on but it went out without me clearing the codes which I thought was peculiar. And I'm low again but no light. I guess I won't worry about it until I need to worry about it. I'd rather spend the $30 -$60 on something else this week...... Hm.. now what could I buy....
Old Oct 18, 2014 | 08:08 PM
chicane's Avatar
Question Assist Please
Ok, I had code P0455, I replaced the gas cap AND replaced the purge valve. I replaced the purge valve with the OEM Bosch purge valve NOT the Hyundai model. I ran it about a week before the code returned (WTF).
I see no reason why the Bosch unit should not do the trick it is not an aftermarket brand.
Just so I don't go out an buy a dozen other purge valves what are some other things that I should check first for that OBDII code that could apply to our vehicles?
Old Oct 24, 2014 | 10:04 AM
chicane's Avatar
Anyone?
Old Oct 24, 2014 | 10:15 AM
Alex_M's Avatar
Check your gas cap again. Take some motor oil and put it around the cap seal like you would on a new oil filter and reset the code. If that works then your cap is defective. If that doesn't work then get a warranty replacement purge valve (I'm assuming you got a new one with a warranty). If that doesn't work, I have no idea.
Also, when you fill up your tank do you go a squeeze or two over to get an even dollar amount? I've been told that can cause gas to get in your purge valve and kill it. I dont know how much truth there is to that, but thats what I've been told.
Old Oct 24, 2014 | 07:28 PM
Kenso's Avatar
If the purge valve is ok and the gas cap is ok then you may have a leak in the system somewhere. Might not be anything you can easily find without a smoke machine to test the system, but it wouldn't hurt to inspect the evap hoses and canister underneath the truck for any obvious problems (hoses disconnected/loose, hole in a hose, damage to the canister etc..)
austinlandroverbill
Apr 1, 2015 06:26 PM
russburcham
May 15, 2013 10:09 PM
two45triox
Sep 23, 2008 10:23 AM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
