Rear door stuck and will not unlock on my 2000 Disco II
Old Mar 8, 2010 | 12:08 PM
marlymarl's Avatar
Default Rear door stuck and will not unlock on my 2000 Disco II
About a year ago my rear door on my 2000 Disco II started not unlocking when I would unlock all my doors, yet i could manually unlock it from the inside of the car by pulling on the inside rear door handle. About 3 weeks ago I tried to open it from the inside which I would normally be able to do and now it will not do anything when I pull the lever from inside the rear door. On the outside of the rear door, the handle is stuck in the unlock position and will not spring back nor can I open it. Any help regarding this will be greatly appreciated.
Old Mar 8, 2010 | 02:14 PM
csbd's Avatar
Pop off the LR oval and apply WD-40 or similar to the works. That should solve the stuck-in-open problem and allow the door to open in the previous manner. I'm guessing the first problem is the electrical lock mechanism and totally unrelated.
Old Mar 8, 2010 | 04:32 PM
If you use silicon spray it wont collect dirt.
This is a 2-3 times a year preventative maintence deal.
Old Mar 9, 2010 | 06:05 AM
Rovin4life's Avatar
child safety lock mechanism fell down. you need a pick to the back door and push up the lever. Have fun.
hubie
Nov 18, 2014 09:27 PM
ImQuattro
May 1, 2014 08:36 PM
kpl1228
Aug 19, 2012 05:33 PM
richierichrover
May 27, 2009 09:42 PM
CL_Reatta
Jul 3, 2007 12:00 AM
