Replacing brake booster - anything I need to know?
Old Jun 1, 2008 | 09:00 PM
roverguy7's Avatar
Default RE: Replacing brake booster - anything I need to know?
if you pulled the master cylinder lines off you need to bleed out the entire system, also if you havnt in a while you might just want to do it anyway
Old Jun 4, 2008 | 10:59 PM
dillhole's Avatar
Okay, so now I am concerned, possibly for no reason:
I can pump away at the brake pedal, and it never gets stiff. Is this because I have not started the truck to create a vacuum yet (still some things I need to do before I fire it back up again), or did I do something wrong? O-ring not fit properly? Something else?
Old Jun 5, 2008 | 05:51 PM
roverguy7's Avatar
sounds like air in your master cylinder
Old Jun 6, 2008 | 01:11 AM
dillhole's Avatar
I was hoping someone would say that. Bleeding this weekend.
Old Oct 30, 2016 | 04:43 PM
Hoots's Avatar
Default Replaced booster/Mc no brakes
Do we need to bleed each caliper? We went from hard brakes to none after installing brake booster and reinstalling original Mc. Does it take unusually long to bleed system? Seemed very straightforward if anyone can help. Thanks
Rover Newbie
Jul 13, 2014 10:46 PM
Garrett
Sep 28, 2010 05:41 PM
rsandmeyer@cox.net
Apr 25, 2010 04:46 PM
Disco2Fever
Sep 24, 2008 09:26 AM
jmt
Mar 11, 2008 11:43 AM
