Ticking From Lower End After Warm Up
Old Mar 25, 2026 | 07:33 AM
  #31
WaltNYC's Avatar
I have a (probably) unpopular opinion about aluminum coolant reservoirs.
In my view, I'd rather see the stress in the cooling system in a plastic reservoir rather than a head gasket. Aluminum reservoirs can mask small problems.
For $40-80 it acts as an early warning sign. Easy to replace, easy to source. Quality of the product may be an issue in some cases. I'd still rather see the stress early.
Old Mar 25, 2026 | 11:22 AM
  #32
Claydog's Avatar
Originally Posted by JohnZo
Looks like a temperature sensor.
Thanks Johnzo. So the donor box must have had a gearbox temp gauge installed after market possibly? The original gearbox just has a plug there. I don’t see a connector anywhere near it.
Old Mar 25, 2026 | 11:23 AM
  #33
Claydog's Avatar
This does make sense. Thanks
Old Mar 25, 2026 | 12:43 PM
  #34
whowa004's Avatar
Not aftermarket just a different vehicle or year, the later years might have had a sensor. I swapped a 1.4 unit from a defender into my disco and I don't remember which way it was but the 1.2 I pulled from mine was different than the one I put in.
Old May 3, 2026 | 08:53 AM
  #35
Claydog's Avatar
Finally got around to replacing front differential. Here’s how the old one came out. Still need to fill differential fluid and have a transmission filter kit coming from AB. Then test drive again.
Old May 3, 2026 | 10:20 AM
  #36
Brandon318's Avatar
Something about 04 differentials that just like to grenade themselves. I feel like it’s always an 04 when it happens. Here was mine…
acg
May 29, 2024 02:10 PM
thom_77
Dec 30, 2019 10:10 PM
04duxlr
Jul 3, 2013 11:02 AM
surfoblb
Feb 8, 2011 06:01 PM
XCELLER8
Apr 23, 2010 08:25 AM
