Valve cover bolts: orings?
Old Aug 2, 2022 | 03:32 PM
wes_in_va's Avatar
Default Valve cover bolts: orings?
I'm working to finish up my head gasket job and I'm reinstalling valve cover gaskets.
The orings/seals on the bolts are toast. I'd love to just replace the orings but I'm having a hard time finding ones that are appropriate. Any suggestions??
Old Aug 2, 2022 | 06:34 PM
Brandon318's Avatar
Are you in the USA? There aren't o-rings on the valve cover bolts on the V8.
Old Aug 2, 2022 | 06:58 PM
wes_in_va's Avatar
Not really o rings but on my bolts there was definitely some material that had degraded and when I look at new bolts from Atlantic British it looks like there’s kind of a seal/o ring thing there?
Old Aug 2, 2022 | 07:06 PM
mln01's Avatar
Agreed. It's not an O-ring per se, but there is some sort of rubbery material there under the head. See pic.
I suppose trying O-rings that fit would be worth a shot.
https://www.roverparts.com/engine/he...dware/ERR7371/
Old Aug 2, 2022 | 11:44 PM
Brandon318's Avatar
Oh wow. Wild. I’ve never seen a new valve cover bolt. Hmm. I wonder if something like Hylomar should be used in its place.
Old Aug 3, 2022 | 03:15 AM
frostythor's Avatar
Could you fit a dowty washer, that a steel washer with a rubber seal on the inside used on hyrualic systems
Old Aug 3, 2022 | 05:11 AM
wes_in_va's Avatar
I got lazy and just pulled the trigger on a new set of bolts from AB.
don’t ask me how much that cost me 😂
Old Aug 3, 2022 | 06:24 AM
Alex_M's Avatar
Just a wipe of silicon under the bolt head would work just as well. Or truthfully I've never used anything under the bolts, never had a leak from that specific location.
Old Aug 3, 2022 | 11:32 AM
RA122125's Avatar
Banned
I wonder if they had a lil rubber on the bottom of those bolts from the factory, to help keep them from loosening up all the time. Doesn't seem like there's a need for a seal there as the valve cover gaskets takes care of that issue, but those lil bolts do vibrate out easily enough. I used a dab of blue Loctite on mine instead, I also mark the bolts with viz-torque so I can tell if they loosen up at all. So far so good, but I doubt that with a fairly coarse threaded bolt, that anything will completely stop them from loosening over time. Unless someone made a locking bolt, like they have for exhaust headers, I think these will always try to loosen up as they are to small and coarse threaded to stay put long term
Old Aug 3, 2022 | 03:20 PM
OverRover's Avatar
Have at it.......
Tony Luna
Apr 1, 2022 03:57 PM
twin6
Jan 25, 2017 09:17 AM
batard
Nov 21, 2015 10:28 AM
maing74
Aug 26, 2011 10:23 PM
rod76
Oct 30, 2009 04:43 PM
