Old Dec 17, 2015 | 12:15 PM
  #3021
number9's Avatar
Default Month One
D2 seems to be coming around after investing in parts/supplies/time, doing a bit of mx every day and regularly putting on miles to build my confidence in the machine.
During under bonnet post drive inspection yesterday noticed coolant tank seep/leak along seam and the belt tensioner was tapping/jerking slightly. More parts on order. Also noticed for first time a nice sewing machine like sound at valve covers.
R&R'd air filter element today installing a Mann "C 25 146" which appears to fit/seal much better than the floppy Fram removed.
Old Dec 17, 2015 | 06:41 PM
  #3022
dgi 07's Avatar
Took the young one "puddle jumping" in my D2. He had a blast. I ended up with pending misfire codes on 4, 6, and 8.
Old Dec 18, 2015 | 10:09 PM
  #3023
CollieRover's Avatar
Finished installing new sump gasket, and new stainless steel brake lines on the rear. Tomorrow front brakes, and then on to overhaul the cooling system.
Old Dec 19, 2015 | 12:51 PM
  #3024
rossagge's Avatar
Got my spare wheel in yesterday. Took it to Discount Tire and had the tire installed. Mounted it up and it just fit 😊
Old Dec 20, 2015 | 11:20 AM
  #3025
I've replaced the oil pan gasket, and it appears to have stopped the leak. Fingers crossed.
Today we painted the front calipers black and the inside of the cover that sits inside the rotor. I was just tired of looking at the rusty ugly thing.
I painted my ladder with Eastwood rubberized undercoating as it rusted out. I had peeled off the coating earlier. I'm curious to see how long, or if, it holds off the rust.
Old Dec 20, 2015 | 03:23 PM
  #3026
number9's Avatar
Default Resevoir
Installed new cooling system reservoir and cap. Leak checked good after proving run.
Old Dec 22, 2015 | 06:09 PM
  #3027
rossagge's Avatar
Installed leather parking brake boot and transfer case boot to replace those haggard original boots. Still working on cosmetics. Gotta hit the mechanical stuff soon!
Old Dec 23, 2015 | 02:00 AM
  #3028
number9's Avatar
Default Tag Light
Found one of my tag lights out. Apparently had been inop for sometime, lamp compartment full of dirty water, negative wire broken at terminal and spring clip/holder badly corroded. Removed corrosion, installed new terminal and ops check good. Deferred gasket leak until later date.
Old Dec 23, 2015 | 04:20 PM
  #3029
number9's Avatar
Default Wipers Good To Go
Installed a new BRITPART D2 rear wiper arm. Due to washer spray issue swapped nozzle from broken arm. Ops check good with Silblade RB114D mentioned in previous post 3002 as not recommended now works very well.
Valeo D2 front wiper blades PN 800-21-4 installed a few weeks ago are performing perfectly in the rain and are smooth/silent.
Old Dec 24, 2015 | 03:25 PM
  #3030
number9's Avatar
Default A/C Clutch Bearing Repack & Belt Tensioner
Wised up a bit today after a couple of past PIA serpentine belt installations on my D2. Prior to this morning's project removed the upper fan guard and fan/clutch assembly for easier/better access. With fan/clutch removed it was also easy to check water pump for bearing wear.
Removed a/c clutch pulley and repacked bearing with grease.
Installed new belt tensioner due to tapping/jerking.
Ops check good and silence is golden after 60 mile run.
