Old 07-01-2017, 07:10 PM
Luckyjayb's Avatar
Nice. Where did you get those at?
Originally Posted by MacRoadie
Front disconnects installed. Rears next.
  #4172
Old 07-01-2017, 07:22 PM
OverRover's Avatar
Thanks, real nice MacRoadie... As if I don't have enough to do, now there's one more thing I have to go FAB.
  #4173
Old 07-01-2017, 07:27 PM
MacRoadie's Avatar
Lucky 8
https://www.lucky8llc.com/products/l...bar-disconects
Pricey, but well made.
  #4174
Old 07-04-2017, 10:18 PM
Luckyjayb's Avatar
Installed the reupholstered headliner, new aftermarket head unit and fixed the water leak finally!!! It's been a rough 2 days
  #4175
Old 07-05-2017, 12:55 AM
MrValingo's Avatar
Got the winch installed. Went pretty smooth
  #4176
Old 07-05-2017, 05:35 PM
Twix's Avatar
Installed extended brake lines. Bled the brakes and took her for a spin. Pedal was soft. Bled them a second time, pedal is nice and firm. But now my traction control thinks I'm spinning 3 wheels on dry pavement (lol). Got it to throw a code for the front left wheel speed sensor.
History: I replaced the front right 2 years ago when I bought the truck, bearing was bad so I replaced the sensor when I did the hub.
How do I check to see if the bearing bad? The grease inside is clean, bluish in colour. Maybe I didn't put the sensor in correctly?
  #4177
Old 07-05-2017, 07:32 PM
Luckyjayb's Avatar
Pic of the new headliner and radio if you can see it
  #4178
Old 07-06-2017, 08:44 PM
Luckyjayb's Avatar
Played with my new Hawkeye total and turned on the heated front windscreen!!!
  #4179
Old 07-06-2017, 09:51 PM
Jeff Blake's Avatar
Behind on my updates... not all from today:
- Front winch and license plate bracket. Smittybilt x20 10k synthetic
- Mantec snorkel
- mantec rear passenger window guards
- bush cables
- terrafirma wheel arches (meh)
- Greg davis rear bumper. Had this welded up today. Great bumper
- resonator delete. highly recommend (still need to get a proper job done on the piping, I just threw in a 2 foot extension and exhaust tip for now)
Next up I am working on a dual air compressor setup. I want to mount it underneath the truck, but it may be too much work and hassle, and space is really tight. I think the only place to put the tank is where the rear sway bar was, but it's awfully hot up there (directly above exhaust pipes)?
Or in the cab as pictured like this
  #4180
Old 07-08-2017, 11:05 PM
MacRoadie's Avatar
Default HD Springs
New HD springs on rear to complete 3" lift. Already had the extended HD shocks on it. Added custom fabricated extended stainless brake hoses, and have wheel speed sensor extenders on the way.
Had 2" spacers with stock springs and it was terrible. Doing it right this time. Will do the fronts at the weekend.
Quick Reply: What did you do with your DII today?
