Old Mar 20, 2018 | 11:45 AM
  #5001
JUKE179r's Avatar
I'm trying to decide which front shocks to put on Myrtle's sagging front end.
I first bought the Terrafirma TF178 w/ +3” four way adjustable shocks.
Then I found these new and cheap, Fox 2.0 Performance series 985-24-127 w/ +2” shocks.
Old Mar 20, 2018 | 11:53 AM
  #5002
Jeff Blake's Avatar
You need new coils to fix sagging, not shocks? Both those shocks look nice though! Has anyone had regular TF all terrain shocks and then switched to one of those? Notice any difference?
Old Mar 20, 2018 | 12:10 PM
  #5003
JUKE179r's Avatar
My old OME set up isn't holding up anymore so I really need both for the front. Shocks and soon RTE springs. My front end is loaded down with steel bumper, winch, aluminum steering guard and steel rock panels.
Old Mar 20, 2018 | 12:13 PM
  #5004
Jeff Blake's Avatar
Originally Posted by JUKE179r
My old OME set up isn't holding up anymore so I really need both for the front. Shocks and soon... RTE springs. My front end is loaded down with steel bumper, winch, aluminum steering guard and steel rock panels.
Gotcha. My front 3” rte springs are working great, no sag. The rears however are sagging 1-1.5”, within a month of installing. That’s with d1 spring seats, too.
Old Mar 20, 2018 | 03:37 PM
  #5005
Saturnine's Avatar
I just installed a full set of those TF shocks shown above -- I like them so far. I run them on "2" and they feel good.
Old Mar 20, 2018 | 07:41 PM
  #5006
Jeff Blake's Avatar
Installed a new wheel hub, CV joint, and oil seal for the front left. Job was way easier than I thought it would be... no fuss, took a couple hours. FYI new hub nuts are 36mm, whereas original nuts are 32mm, so make sure you have a 3/4" drive socket set ahead of time.
Using the old hub for a spare tire swingaway
Old Mar 21, 2018 | 03:23 AM
  #5007
The Deputy's Avatar
Jeff, are you going to seperate the hub? Because, without the center nut, it will come apart...the large center nut (that goes on axle shaft) is what holds the two portions together. If you plan on using the whole hub assembly, you'll have to weld the outer flange to the inner hub bearing housing. But, I like the idea of using it...good thinking.
Brian.
Old Mar 21, 2018 | 10:16 AM
  #5008
JohnHZ3's Avatar
Finally completed a swing-away spare tire carrier. More details can be found here:
https://landroverforums.com/forum/di...-bumper-87761/
Attached Thumbnails What did you do with your DII today?-back.jpg   What did you do with your DII today?-hinge.jpg
Old Mar 21, 2018 | 10:36 AM
  #5009
Jeff Blake's Avatar
Brian.
The studded hub piece should separate from the bearing housing, then a short tube of steel welded to the backside to accommodate the backspacing. And throw away the heavier bearing housing portion.
Old Mar 21, 2018 | 11:04 AM
  #5010
The Deputy's Avatar
Two thumbs up!
That was what I was getting at, were both on the same page.
Brian.
