Old 06-01-2018, 08:37 AM
wjsj69's Avatar
Ilokit alot. Nice job Brian!
The Deputy (06-01-2018)
  #5422
Old 06-01-2018, 08:46 AM
Disco_Dion17's Avatar
Made a light bar.
Brian.
where dis you get that front bumper. I like the look of it! Also, where is that winch mounted!?
  #5423
Old 06-01-2018, 11:17 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Made both, bumper and winch plate. Basically, the winch plate utilizing the same bolt(s) that hold the bumper on. It's tucked up in there nicely...bit lower than a winch/bumper mount...but it was worked okay for me so far. Keeps approach angle tighter, though. Skid plate utilizes the mounting holes for the removed swap bar. Swap bars turned into the front grill guard.
Yes, if I see something laying around...I make it into something...lol.
Brian.
  #5424
Old 06-02-2018, 07:17 PM
Jeff Blake's Avatar
Rebuilt the transmission brake with new shoes, springs, hardware. Painted the drum
Before & after
  #5425
Old 06-03-2018, 06:25 AM
No Doubt's Avatar
Before & after
Sharp!
  #5426
Old 06-03-2018, 08:27 AM
Wesley Lueders's Avatar
Default Recently Acquired
It's so funny. I've been turning wrenches on old motorcycles for years. I always find that regardless of inspections, I really get to know the vehicle once it's home and I'm in cleaning mode. Today, I found the rear license plate bracket was MIA, and the PO's plate was essentially glued on the door. After careful removal, a bracket was fitted, and all is well.... Replaced the drivers' sun visor clip and checked for any more air in the cooling system after the PO did a HG job just a couple of weeks ago (with fresh heads...)
It has been about 80 miles on it since the HG job, and I'm still getting a faint smell of antifreeze from the engine compartment, but no noticeable loss of coolant or leaks. So today is cooling system pressure test day..... I also was going to order an ultra gauge, but they're on back order until July
  #5427
Old 06-03-2018, 09:13 AM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Scangauge II is another nice solution.
  #5428
Old 06-03-2018, 01:54 PM
mollusc's Avatar
Installed Abran's wonderful driver's door lock pin as a precautionary measure, and also serviced the transmission with new filter and fluid.
Since my pump didn't fit the tops of the bottles, I ended up removing the front driveshaft in order to have enough room to fill the transmission again. Great design, Land Rover!
  #5429
Old 06-03-2018, 05:51 PM
Fastercat's Avatar
Decided to finally do something about the flares.
  #5430
Old 06-03-2018, 09:38 PM
JUKE179r's Avatar
nice! Did you wet sand them first before painting? What kind of paint did you use?
Quick Reply: What did you do with your DII today?
